Ka24de-ka24det
So i have already posted looking for a turbo kit and someone on here has PMed me and has a kit i am fairly interested in BUT!
A friend of mine told me that i should not turbo a stock KA24DE that has 160 XXX miles on it as it probably wont hold much past 3-4 lbs of boost for any length of time and its my DD/fun track car.... what do you guys think? im looking for 250-275 RWHP? thanks for the input. Gary |
Depend what shape your engine is in.
If the compression checks good and it does burn oil.. Boost it 7-8 pounds would be easy on a decent engine, as long as fuel and ignition needs are met. Have at it |
#3 | |
![]() Join Date: Aug 2008
If you are looking for 250-275 WHP, you would be right at the limit of a stock KA24DE's internals. It would work, don't get me wrong, but to protect your investment, you should shop around for another KA short block and have it rebuilt with some lower compression pistons. A bit more cash, but you would have a very solid engine that could run more boost, would be capable of more power and would last far longer than an internally stock KA.
![]() Join Date: May 2008
My buddy had his KAT running on stock internals for about 4-5 months. After dat his rings blew out..
"Drive it like you running from the cops" |
![]() Join Date: Jan 2007
compression test...if its too low (155) then dont go at it. mine KA-T lasted 6 months ONLY due to my turbo coming off the manifold while pushing 12psi (nuts and studs back out and.....well its a long story lol) . Cracked cylinder 4 rings....tore the engine down and replaced pistons and rings
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
#11 | |
Man w/ CTSV & a Car Seat
![]() What it all comes down to is health of the bottom end and tuning. Stock rods been proven to hold over 600hp. As far as the pistons, folks at KA-T.org has been pushing the numbers higher and higher. |
![]() Join Date: Dec 2002
Exactly. Fuel. Lots of it.
#15 | |
Yea, maybe on 116 octane racing fuel and massive amounts of it. I only suggested new pistons to protect the investment. Besides, I'm sure those 600hp "stock bottom ends" are freshly rebuilt. |
#16 | |
![]() Join Date: Apr 2008
#17 | |
I meant 5-6 months
