Old 11-12-2008, 10:04 PM   #1
rb20hatch
rb20hatch is not welcome here anymorerb20hatch is not welcome here anymorerb20hatch is not welcome here anymorerb20hatch is not welcome here anymorerb20hatch is not welcome here anymorerb20hatch is not welcome here anymorerb20hatch is not welcome here anymorerb20hatch is not welcome here anymorerb20hatch is not welcome here anymorerb20hatch is not welcome here anymorerb20hatch is not welcome here anymore
Red face silveight ls1
ok so im thinkin of doin an ls1 swap and want to know if its worth it and how long it would take to do it. i willl have everything to bolt it right in from hinson supercars and they are goin to do the wire harness and send it back to me so i can bolt the motor in and have her running in a weekend. what i think y its worth it because the sr is 205 stock and then you pay 2k for the motor and then all the bolt ons like intercooler bov and so on and my limit for the swap is 9500 and i will not get that much power as an ls1 would just bolt straight in 3500 for the ls1 with 350 horse and 9500 i can buy everything for ls1 bolt in and a rolling shell and motor. so if any one has had an sr and now has an ls1 s13 please enlightin me if you like it or not.
rb20hatch is offline   Reply With Quote
Old 11-12-2008, 10:17 PM   #2
Walperstyle
Walperstyle's Avatar
never ask opionated questions
either you trust the people that are doing it, or you dont. Its your money.
If that was my budget on an engine, I'd do the work myself due to not trusting anyone.
have a nice day.
KA-T ORG-Function over Flush
Old 11-13-2008, 09:02 AM   #3
rb20hatch
i am not paying to have it put in i am doing it myself the only thing i am paying to have done is the wire harness and sending it out to hinson supercars for 320 everything else im doin it at my work because i have a lift. i kno alot about cars but suck at wiring u dont have to be a dick bout it
Old 11-15-2008, 09:08 PM   #4
Lr308
Lr308's Avatar
Lr308 is an unknown quantity at this point
LS1 350rwhp 28mpg hwy (500rwhp nitrous) on stock 98 block! Need to add arp rod bolts. Tons of aftermarket products,& many setups to choose from. save money and time check out pxracing.com just send in your harness.
Lr308 is offline   Reply With Quote
Old 11-16-2008, 09:22 AM   #5
DeathMetal
DeathMetal is an unknown quantity at this point
Just to site what can easily be done with your spending limit and an LS1.
1990 Ford Mustang LX - The Orphan - PHR Project Car - Part 5
Roughly 9800$ No nitrous and you would be in your spending limit. This would all be obviously DIY.
'90 Ford Mustang LX $1,000 Used
'02 Camaro long-block $1,500 Used
T56 transmission with shifter and good McLeod clutch $800
Used Camaro wiring harness, PCM, LS6 intake manifold, and coil packs $710
Used ported 5.3 heads and cam $800
Custom American Racing headers $1,400
Ported stock throttle body $108
McMahon Motorsports LS1 adapter harness $199
Fuel system (255-lph pump, C5 filter, AN lines) $220
Nitrous Works LS1 nitrous system $570
Nitrous Works Purge Kit $95
Used aftermarket cat-back exhaust $150
Miscellaneous wires and connectors $85
Dyno tuning $300
UPR tubular front suspension $699
UPR rear control arms $199
Used rear antisway bar $45
Used 28x10.5 slicks $183
Used Weld Draglites with skinnies $250
Used Nitto drag radials $150
Thunderbird Turbo Coupe pedals $40
Custom driveshaft $275
New battery $60
DRAG TEST RESULTS: Best on Nitto 245/50/16 Drag Radials
11.61 at 122.11
Best on 26x10.0 slicks
11.26 at 122.79
Best on 28x10.5 slicks
11.21 at 121.44
Best with nitrous (28x10.5 slicks)
10.73 at 132.02
Observed fuel economy
25 mpg (combined, mostly highway)
Note: Car is making 405-450whp without nitrous.
DeathMetal is offline   Reply With Quote
Old 11-16-2008, 09:28 AM   #6
atutt
atutt's Avatar
atutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond repute
BTW... Only the Corvette LS1's were rated at 350hp... The f-bodies were 305hp... Oh and you guys (Americans) were allowed to have the GTO.. Which I think was 345hp.
So to the OP. Your LS1 may or may not be rated at 350hp.
atutt is offline   Reply With Quote
Old 11-16-2008, 09:41 AM   #7
Lr308
Lr308's Avatar
its not stock it stock rotating assembly! cam heads headers intake D.D.
Old 11-16-2008, 09:47 AM   #8
atutt
atutt's Avatar
I saw no mention of those in the OP's posts.
Old 11-17-2008, 05:46 AM   #9
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I got a buddy who did all the work himself...when he added everything up, he was at about $7800. If you want another option for a mount kit for an LS swap, check out PXRacing.com like already stated and try to get ahold of Frank. Last time I've talked to him, he put down 305 whp 360 ft/lbs on a stock engine with intake and exhaust. Still using the stock headers iirc.
PS: Dont ever expect any swap to be done over a wk end, specially if you've never done it before. Always add in Murphy to fuck shit up for you the last minute.
CLICK HERE!!!
Old 11-17-2008, 10:38 AM   #10
trsilvias13
trsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to beholdtrsilvias13 is a splendid one to behold
if you want straight up bolt on no cutting/welding subframe - check out sikky.com. They have everything you need to bolt onto your car. However it is a bit more expensive. But also consider you do not need to get a gto oilpan, cut/weld subframe, DS included in sikky's kit, do not need to get motor mounts from a vette (like hinson), it is about the same price as the Hinson kit.
Daft also make a good kit too - with headers for a good price.
Check out silviav8.com if you have not already.
There are many options to do a ls1, just which everyone you feel comfortable with (wallet + time + DIY knowledge).
trsilvias13 is offline   Reply With Quote
Old 11-17-2008, 12:10 PM   #11
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
is it worth it? - only you can answer that AFTER you're done.
How long does it take? Depends. If you just want stock, bare minimum swap vs custom fabbed, it will vary as your wallet/skills/tools allow.
Running in a weekend - sure, maybe, as long as nothing unexpected comes up and you got all the parts ready. And depends on your definition of what running is.
Sir is offline   Reply With Quote
Old 11-17-2008, 03:53 PM   #12
rb20hatch
i mean i did my first sr20 swap long time ago didnt know much about cars and it was just me and my best friend and he had it in like 1 day and very limited tools. but now that i work at volvo i have a lift and like 10k worth of tools so tools skill and space is no prob to do and ill have 35k so if i have to spend any extra im not worried but my budget is under 10k but i have a friend who had done it before and started on friday and finished sunday so im hoping to have it done quick if not o well
Old 12-05-2008, 04:39 PM   #13
RUTH'LESSDET
RUTH'LESSDET's Avatar
RUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to allRUTH'LESSDET is a name known to all
Send a message via AIM to RUTH'LESSDET
pxracing.com is the way to go as stated above. Frankie did my harness for my ls2 swap !!
91 Sil80-Sold, LS2 Powered 1997 240sx-Traded, 2005 350z-Sold, Whats next?
RUTH'LESSDET is offline   Reply With Quote
Old 12-06-2008, 02:56 AM   #14
dvdevo
dvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enough
If you can spend less than 7k(which would be hard) then it might be worth it. I did the swap before and probably spent 9k because i paid wayyy too much for the motor. In the end it wasnt worth it because the motor I got was bad and transmission was bad too. But even if it did work it wasn't worth the trouble. Just stick with an sr.
dvdevo is offline   Reply With Quote
Old 12-06-2008, 05:59 AM   #15
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
I have an S13. Up until 3 years ago I had a redtop SR. Then I swapped in a chevy small block genI. The reason I did not go with an LSseries is because the genI has much much more aftermarket support.
A lot of people who put down the genI don't know that you can get aftermarket blocks that are much better than what GM can offer in their LSseries or even LSX crate motor.
The chevy small block genI is probably the most popular engine ever used in production or racing application. There is HUGE aftermarket support for this swap.
The LSseries is getting popular but it's not there yet. The reason GM sponsors an LSX racing series is because given the choice, most racers would rather use an aftermarket block over the LSX. They limit all cars in this series to LSX to promote their engine.
Just some counterpoints to think about. You can find stock GM GenI block very very very cheap anywhere. LS1 costs slightly more, but lately they are getting very popular so I'm having trouble finding used LS1 for below $3000. I can buy new GenI blocks from GM for $1500 with warranty.
You will find very few people who have V8 swaps, and fewer still who have SR then gone V8. So your questions will be very difficult to answer.
In my personal experience, I set my car up for autocross and short roadcourse. I need low end response more than peak power. The GenI has better bottom end torque than the LS1. Plus it's cheaper and easier to tune the carb than trying to do a reflash. I can fine-tune the fuel curve on the fly in a few minutes intead of trying to reflash with an ECU.
You will run into a lot of things, like power steering, exhaust clearance, mounts, driveline alignment, etc. It goes on and on and on. Been there done that.
Good luck.
g6civcx is offline   Reply With Quote
Old 01-02-2009, 11:38 AM   #16
SicBastard
SicBastard's Avatar
I've driven both a 413 whp SR powered S14, and a 400 fwhp LS2 powered S14. There is no comparison. To make 400 hp out of 1/3 the discplacement you're going to have to have a lag heavy turbo. The biggest problem with the SR was the gearing. Every time I upshifted I was out of the power band again. While waiting for boost I was literally getting passed by minivans. The LS2 pulls now. PM me your e-mail address and I'll forward you my budget for my entire LS7 S14 build. I recently have been thinking about putting the LS7 heads I have on the shelf for a year or two and just slapping in a 5.3 L motor just to get her on the road. You can pick up the LS based 5.3 300hp truck motors running and complete for under a grand at the junk yard all day.
BURN OUT IN YOUR FACE!
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
Old 01-05-2009, 01:36 PM   #17
Otto347
Otto347's Avatar
243 casting heads on a 5.3 with LS2 intake and a cam
To me an LS1 is great but the iron block LSx (6.0-5.3-4.8) for the money and a few bolt on parts is a far better investment.
