![]() Join Date: Apr 2007
Why did my sr20 blow?? Need your opinions.
Hey guys. Here's my setup:
S13 sr20det.45k miles, Gt30r twin scroll at 19psi Arp studs Tomei gasket Setup was professionally tuned. Tune was verified to be running safely. I've had the setup running absolutely great for 3 weeks. Went to the track. Did one run, and there goes my rod bearings. Drained the oil, and found gold tint. So I know that it's the rod bearings. What I don't get is why did it ruin my bearings? Can knock kill a motor that fast. I was running about 19 on the fc when doing a wot pull. Oil pressure was great. It's now making me think that the sr20s physics just can't handle the pressure. Car ran perfect before. |
![]() Join Date: Jul 2005
Did you run a heavy weight oil and repeatedly bang 7200rpm?
Or you had 15* btdc of timing at 18psi of boost, and it ate the rod bearings. Or it starved for oil, check if the oil pan is dented up into the pickup. In fact sometimes it completely falls off on redtops. You have to tear down and inspect for clues. Everybody knows you need an S14 bolt on pickup for the redtop- wheres yours? |
#3 | |
I think only my idle is 15 btdc at idle. I ran synthetic 5w30 and I wouldn't hit the rev limiter. But my tuner said 8k redline would be okay since I have upgraded springs and cams. |
And to add this was a strict street car. Didn't do any tracking with it. The metal in the oil was so small we needed a light to see the gold tint. Which to me means that maybe it was slowly degrading.
Sent from my SM-G925T using Tapatalk |
Ha-ha. Well. I meant before I went there lol. It was one 1/4 mile run. Just a plain run. And started hearing some ticking. That's it.
![]() Join Date: Aug 2011
Are you seriously asking why your engine blew ? On a forum ?
Reminders : -we know absolutely nothing about your engine. Who built it, what machining was done, what parts are in. -what did you got "3 weeks ago" ? -stock SR20DET, 45k miles ? Sorry, i don't believe it. -gt30, 19psi, stock pistons ? Yup, PEBKAC. -we know absolutely nothing about how it was used, except it "was a strict street car until you decided to track it" which tells us... well, nothing. -do you have anything at all to monitor your engine ? like AFR gauge, EGT, fuel pressure ? So far it can range from clearance / machining error to PEBKAC. |
#10 | |
I have aem wideband and verify my air/fuels constantly. Car is tuned on a apexi fc d detro. Made 380whp on a mustang dyno. I think all the hype about having a sr at that power level last is bullshit. I would hope the experts would say something. Thanks |
![]() Join Date: Mar 2008
My stock rebuild SR made those power levels for like 2 years before blowing due to a boost controller malfunction.
Why are you running 5w-30?
96 240sx S13 SR20 521 WHP 405 TQ |
19psi from a gt30 on stock bottom end is a bit asking for trouble. Stock pistons are weak on ringlands, they usually break there from very few det. If the bearings are gone and they have been done recently, then it is related to bad clearances.
You won't know what has gone until you tear that engine down, so i suggest you start there. Maybe the oil pump got problems and the bottom end was starved, too. |
#14 | |
As to this new question, yes, it is common for "tuners" to set the ignition timing too far advanced, as much as 15* btdc for boost situations in the 9-19psi range. The knock sensor will typically report nothing is wrong. Meanwhile, this timing setting will eat up the rod bearings over time, gradually wearing them out and causing failure. You will find the bottom halves of the bearings scored as if you need more proof that the piston were prematurely being forced down. |
![]() Join Date: Mar 2009
I'm curious, what about the guys that run e85? I've always heard one benefit is being able to run more ignition timing, but in reality you couldn't run much more timing regardless of the fuel because of the wear on the rod bearings right?
Absolutely not. The FSM gives you pressure targets when cold and hot, at idle and 3000 (or 3500)rpm.
Hot, 3000rpm pressure is a WINDOW, too much pressure is bad too. Our oil pump regulation is pressure based, more pressure = less flow, so you really want the thinnest oil that gets you in that pressure window while maintaining idle pressure above threshold (as long as your engine does not eat it) at oil operating temp. Basically, unless you live in dubai, if you need 15w50 to get that pressure range, your oil pump is worn. Change your oil pump before the lack of flow makes further damage. I went that way too, ended up using 10w50 then 10w60 to get the correct pressure, but oil was heating more, thinning and wearing even faster. And then i replaced the pump. Now i can use 5w40, heat problems are gone (oil hardly reach 110° on track when i used to stop at 130° before, after 10mins), the oil is still good after 2000 miles, and the cost per littre is halved ... |
#17 | |
When there is too much gnition advance like kingtal0n says, the engine kind of "knocks", it vibrates badly and has less power (this is not det). You can't miss it. E85 guys stop under that "lower power" threshold, and it is way higher than what you get with 93 octane. My CA has more than 20° @ WOT with 18psi of boost for example. I start feeling that "knocking" around 30°. |
So what's the timing threshold in boost on e85, if 91 is around 8-9 degrees?
Also this is incorrect? From the fsm. Where I live it's between 60-120 year round. http://i118.photobucket.com/albums/o...rtible/Oil.jpg |
#20 |
I really wasn't, refer to my previous post. I've been running 15w50 in my sr for 6 years and it still runs as good as it did when I first swapped it in '09.
#21 | |
I guess the conclusion I'm going with is maybe my oil pressure was low causing bearing failure. Im proly going to build the block and see how long the motor will last at 500whp. Then I'll go back to a ls1 if it doesn't stand up to it. Sent from my SM-G925T using Tapatalk |
#23 |
I run 15w-40 in my VET. I also live in a hot humid climate where those viscosities are acceptable.
There's a multitude of reasons your motor could've popped. More than likely though, your motor was about to shit the bed anyway, the drag strip was just the final nail in the coffin. A tear down is in order to inspect everything.
My SR20VET |
#24 |
![]() Join Date: Sep 2005
I change oil viscosity and tunes, according to the weather!
It's tear down season!!! Sent from a Highly Tuned Note 4.5!!!
#25 |
It might have been the 5w30. I mean I was running it through 90-100 degree weather. Maybe the oil was too thin causing it to wear fast. Yes. It's true that I could of been running on a hurt motor. I'm gonna look into building the block and seeing how that goes. I just wanted some clarification of things that can kill any motor. I'm aware that knock. Running lean. All of that can kill a motor fast. But rod bearings for me have always been running low on oil. Which I made sure not to do. You gotta pay to play.
#26 | ||
As far as the oil go, i don't know what FSM you are talking about, but here is the S14 SR20DET one. http://www.240edge.com/manuals/s14_sr20det.pdf Look at page LC5 (numbered 122 in the pdf file) oil pressure when hot at 3200 = 3.14 to 3.92bar, period. Chose you oil accordingly, if you need 10w50 to be in that window and don't live in a very hot country, you need a new oil pump. Quote:
You won't see how long the motor will last because the transmission will be long gone at that power level. You will start breaking gearboxes from 350hp with sticky tyres, or even lower depending on how you drive the car. You need a stronger gearbox. Easiest route is the Z32 gearbox conversion, but they are kind of old, crappy and have loooooooooooooooooong gearing ... Z33 conversion is much better in every aspect. But it is more expensive, and you will need some massaging work (with a bigass hammer) on the firewall and tunnel. But it really is worth it. GB is very smooth, precise, supports high revs shifting, and has an interesting gearing. |
#27 | |
I wish there were more people pushing good power with sr20s that lasted a while for them. For competition I mean go for the most reliable setup. But time attack cars like scorch s15 and motive s14 have been having good luck with them so hopefully they can stand up to the abuse. |
#28 |
![]() Join Date: Apr 2003
Trader Rating: (33)
Let me guess spun bearing on #3? If so there is a solid explanation for it as I have seen almost every SR with a spun bearing be piston 3 while drag racing.
#30 |
![]() Join Date: Dec 2004
Trader Rating: (58)
Engine oil didn't hurt the engine
20 psi on a 30r did It's stock junk, regardless of 'how it is tuned'. One little ping can ruin the day, or constant knock that you didn't (really, you can't hear in the car at speed if you're not trained) recognize smashed the rod bearings to smithereens (an already week item on these cars) Nothing more, nothing else.
