Old 10-22-2002, 02:04 AM   #1
adey
adey's Avatar
adey is an unknown quantity at this point
I was talking to a friend earlier tonight about the importance and/or application of expensive, "high performance" clutches and it led me to an interesting conclusion:
I don't need a 600 dollar clutch!
Unless, of course, someone here can convince me otherwise. <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> I do no drag racing whatsoever (I don't see the point) and am not into dropping the clutch... so why bother?
the only time that I do 'abuse' my clutch to any extent is when I go canyon carving. Multiple downshifts, double clutching and relatively hard shifting (nothing like the dragstrip, though) is all my clutch will see, really. I feel that my stock clutch performs adequately.
That, and I'm on my stock, 155hp engine with no mods.
adey is offline   Reply With Quote
Old 10-22-2002, 07:58 AM   #2
hurleyboi514
hurleyboi514 is a well-known jackass
Send a message via AIM to hurleyboi514
i did the same thing. &nbsp;i went to autozone and got a $100 clutch kit. &nbsp;pressure plate, disc, tools, bearings, all i needed. &nbsp;works fine for all that massive power of........ &nbsp;155 hp! &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/cry.gif" border="0" valign="absmiddle" alt=''>
HighTach Motorsports
hurleyboi514 is offline   Reply With Quote
Old 10-22-2002, 01:01 PM   #3
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
just a side note but double clutching does the least amount of damage to your clutch of any kind of shifting b/c when double clutching properly you are rev matching... &nbsp;there is almost no friction b/w the clutch and flywheel once you've rev matched. &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
you are a hundred percent correct though. &nbsp;the oem clutch will do the job as long as you aren't beating on it, and slippnig the clutch a lot. &nbsp;Once the clutch is holding the flywheel, it's not gonna let go unless you have more power than it is rated to handle or its worn out.
I would like to have a SPEC stage two b/c I like haveing a very precise stiff clutch that I can beat on a little if I want, and not have to worry about it heating up and not grabbing as hard as I like. &nbsp;When on the track my clutch does start to slip a bit, but only mildly, and only b/w shifts. &nbsp;My clutch is also fairly old soo.. &nbsp; The SPEC is by no means is $600. &nbsp;I believe enjuku sells them for around ~$280 or something..
sykikchimp is offline   Reply With Quote
Old 10-22-2002, 02:34 PM   #4
oister
oister is an unknown quantity at this point
spec 2 is NOT stiff...not much different from stock.
oister is offline   Reply With Quote
Old 10-22-2002, 04:22 PM   #5
nrcooled
nrcooled's Avatar
nrcooled is an unknown quantity at this point
Send a message via Yahoo to nrcooled
My clutch is slipping slightly after my trip to VIR. &nbsp;My question is w/ the SR though, &nbsp;I am probally making 215 lb/ft of tourque. &nbsp;What kind of clutch should I replace the current one with? &nbsp;Taking into account that road racing is the only time I really get on the clutch.
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP
nrcooled is offline   Reply With Quote
Old 10-22-2002, 06:04 PM   #6
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
whatever you do, don't get a 6 puck clutch for daily driving! not saying it hasn't been done, but it's not the funnest experience.
02 Blazer X - 90 240SX w/SR
oh noes
whateverjames is offline   Reply With Quote
Old 10-22-2002, 06:36 PM   #7
adey
adey's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sykikchimp @ Oct. 22 2002,12:01)</td></tr><tr><td id="QUOTE">just a side note but double clutching does the least amount of damage to your clutch of any kind of shifting b/c when double clutching properly you are rev matching... there is almost no friction b/w the clutch and flywheel once you've rev matched. <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''></td></tr></table><span id='postcolor'>
Yes.. that all works in theory, but I'll be the last to claim that I double clutch perfectly every time... <img src="#/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>
Old 10-23-2002, 08:54 AM   #8
sykikchimp
WOW addicted
sykikchimp's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (oister @ Oct. 22 2002,4:34)</td></tr><tr><td id="QUOTE">spec 2 is NOT stiff...not much different from stock.</td></tr></table><span id='postcolor'>
I know it's not stiff, but it is more capable than the OEM clutch. &nbsp;I wasn't meaning stiff in the "clutch pedal won't go down" sense.
Old 10-23-2002, 09:20 AM   #9
Foxcolt
Foxcolt's Avatar
Foxcolt is an unknown quantity at this point
Send a message via AIM to Foxcolt
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (nrcooled @ Oct. 22 2002,5:22)</td></tr><tr><td id="QUOTE">My clutch is slipping slightly after my trip to VIR. My question is w/ the SR though, I am probally making 215 lb/ft of tourque. What kind of clutch should I replace the current one with? Taking into account that road racing is the only time I really get on the clutch.</td></tr></table><span id='postcolor'>
Spec star stage two. Great clutch. Next meet I'll let you try it out to see how you like it. Reasonably priced also.
Jed <img src="#/f/iB_html/non-cgi/emoticons/devil.gif" border="0" valign="absmiddle" alt=':devil:'>
Driftec
www.midatlantic240sx.com
Foxcolt is offline   Reply With Quote
Old 10-23-2002, 05:24 PM   #10
Danio
Danio is an unknown quantity at this point
So what's a good clutch if I do kick the clutch quite a bit?
Danio is offline   Reply With Quote
Old 10-23-2002, 05:26 PM   #11
adey
adey's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Danio @ Oct. 23 2002,4:24)</td></tr><tr><td id="QUOTE">So what's a good clutch if I do kick the clutch quite a bit?</td></tr></table><span id='postcolor'>
An ORC or OSGiken clutch should meet your requirements... basically, anything that costs $600 or moer. <img src="#/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''> &nbsp;
What do you drop/kick/abuse the clutch for?
Old 10-23-2002, 05:36 PM   #12
wherezmytofu
wherezmytofu is an unknown quantity at this point
clutches r for girls... its all about the torque converter! &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/sarcasm.gif" border="0" valign="absmiddle" alt=':sarcasm:'>
wherezmytofu is offline   Reply With Quote
Old 10-23-2002, 05:41 PM   #13
adey
adey's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (wherezmytofu @ Oct. 23 2002,4:36)</td></tr><tr><td id="QUOTE">clutches r for girls... its all about the torque converter! <img src="#/f/iB_html/non-cgi/emoticons/sarcasm.gif" border="0" valign="absmiddle" alt=':sarcasm:'></td></tr></table><span id='postcolor'>
<img src="#/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> &nbsp; Bring your torque converter up to touge with me and we'll see how my sissy clutch does against your manly torque converter!! &nbsp; <img src="#/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>
Old 10-23-2002, 09:48 PM   #14
wherezmytofu
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (adey @ Oct. 22 2002,7:41)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (wherezmytofu @ Oct. 23 2002,4:36)</td></tr><tr><td id="QUOTE">clutches r for girls... its all about the torque converter! <img src="#/f/iB_html/non-cgi/emoticons/sarcasm.gif" border="0" valign="absmiddle" alt=':sarcasm:'></td></tr></table><span id='postcolor'>
<img src="#/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> Bring your torque converter up to touge with me and we'll see how my sissy clutch does against your manly torque converter!! <img src="#/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''></td></tr></table><span id='postcolor'>
<img src="#/f/iB_html/non-cgi/emoticons/laugh.gif" border="0" valign="absmiddle" alt=':laugh:'> &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/laugh.gif" border="0" valign="absmiddle" alt=':laugh:'> &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/laugh.gif" border="0" valign="absmiddle" alt=':laugh:'> &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/laugh.gif" border="0" valign="absmiddle" alt=':laugh:'> &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/laugh.gif" border="0" valign="absmiddle" alt=':laugh:'>
your clutch--> <--my torque converter
Old 10-24-2002, 02:32 AM   #15
adey
adey's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (wherezmytofu @ Oct. 23 2002,8:48)</td></tr><tr><td id="QUOTE">your clutch--> <--my torque converter</td></tr></table><span id='postcolor'>
Save the funky butt-lovin' for my tailpipes, not the clutch, tofu! <img src="#/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''> &nbsp;
You'll never come close enough in the canyons to get that torque converter of yours anywhere near me!
Old 10-24-2002, 07:32 PM   #16
S14lover
S14lover's Avatar
S14lover is an unknown quantity at this point
HAHA you said tailpipe hahah.....no seriously &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
She ****ing hates me ....TRUST!
S14lover is offline   Reply With Quote
Old 10-24-2002, 10:39 PM   #17
chinderer
chinderer is an unknown quantity at this point
The SPEC stage 3 clutch can handle 347 lbft, which is plenty for the SR20 and it still has a sprung hub for smoother engagement.
chinderer is offline   Reply With Quote
Old 10-25-2002, 10:37 AM   #18
sykikchimp
WOW addicted
sykikchimp's Avatar
you might also want to check out Fresh Alloy.. &nbsp;TY Yapp is using a 240mm Flywheel from the KA24E truck, and a clutch to match, and says it gives a LOT more torque handling ability, and feels like stock.. &nbsp;something like 500ft lb. &nbsp;you might PM him..
Old 10-26-2002, 12:07 AM   #19
adey
adey's Avatar
wow, that sounds interesting; I've never heard of using a truck KA's flywheel.
What's the stock clutch diameter? I imagine it would be rather hard to find a performance clutch for a nissan TRUCK though, eh? &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/notify.gif" border="0" valign="absmiddle" alt=':notify:'>
Old 10-29-2002, 01:54 PM   #20
kbounds
kbounds is an unknown quantity at this point
(from TY on FreshAlloy)
Design Product of Huntington Beach, (714) 892-1513 has a 16v KA flywheel that takes the 240mm clutch/pressure plate.
Clutch? Whatever flirts my fancy... Ranging from Nismo (280ZX Turbo) to actual truck clutch (aka DPro)... I'll most likely end up using the ACT street clutch with it's 400ft-lb torque capacity. If I need a bit more at lesser price, there's a 500ft-lb truck clutch available... hehehe... Basically, any 240mm clutch application for Nissan is fair game, and that includes the NA Z32s...
Keith
Red! '97 240SX SE
VLSD, N1, t3/t04e
kbounds is offline   Reply With Quote
Old 10-29-2002, 07:20 PM   #21
GamblerZ
GamblerZ's Avatar
GamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enoughGamblerZ will become famous soon enough
Send a message via ICQ to GamblerZ Send a message via AIM to GamblerZ Send a message via MSN to GamblerZ Send a message via Yahoo to GamblerZ
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">whatever you do, don't get a 6 puck clutch for daily driving! not saying it hasn't been done, but it's not the funnest experience.</td></tr></table><span id='postcolor'>
I have the ACT 6-puck copper and it is miserable street driving. It is either engaged or not...no middle. Great for launching though and will hold sick HP.
I hope so because it needs to hold this...
Don't bother asking about the torque curve. &nbsp;It vanished on us for some reason. &nbsp;damn dyno-gremlins. &nbsp;<img src="#/f/iB_html/non-cgi/emoticons/mad.gif" border="0" valign="absmiddle" alt=':angry:'>
Visit WTI - WestTexasImports.net
GamblerZ is offline   Reply With Quote
