01-01-2009, 03:29 PM | #1 |
Rb20 help
So i got this dude, wantin to sell me his S13 with a RB20 in it for 3k. so in my mind im like but then i think. 3k for a running S13 with a RB20 is just too good to be true. so i wanna know what you guys think. should i go for it and buy it and PRAY theres nothin tragic wrong with it or should i not buy it.
Details as follows: RB20DET R32 Skyline motor swap Full SDS Programmable Standalone 3-Bar Map stage 4 or 5 (Not Sure) Dual Disc Racing Clutch Exedy Nismo 3 Inch Cat Back – Custom 2.5 inch Downpipe Extra set Steel Rims 5 Point Harnesses Was Told Engine Has cams CX Racing Aluminum Radiator Shot Throw Shifter Full Front Mount Intercooler – 2.5 inch Piping New Starter New Windshield NO RUST Rear mounted battery in box Pics: What do u think i should do. |
01-01-2009, 03:34 PM | #2 |
Fucking rat's nest under the hood. I wouldn't pay a grand for it as is, and that would only to be to part it out. But I'm sure plenty of kids would give a left nut and more for such a turd.
01-01-2009, 03:52 PM | #3 | |
keep the feedback coming. thanks to all that puts in their comments |
01-01-2009, 11:15 PM | #4 |
His piping is backwards by the look of it... Top pipe should run across the engine bay under the rad hose... Bottom pipe should go out to the drivers side of the car and they both meet the IC in the middle.
Also wiring looks ridiculous... No Cam angle sensor... No Recirc hose connected to the bov... I can guarantee it doesn't have cams, RB20 cams are insanely priced and this looks like a budget build... And no timing belt cover? Thinks his OEM cam gears are cool = FAIL I would suggest staying clear of this horror story. What the piping should look like. |
01-02-2009, 06:29 AM | #6 |
Thanks alot guys, think ill wait for a nice SR to roll around my way. til then ill keep ridin my GSX-R 600 (possibly soon for sale lol)
Thanks again, you all saved me the trouble of a Phucked up RB |
01-02-2009, 07:47 PM | #8 |
that thing looks like a nightmare under the hood. if it runs and drives good id say take it for a test drive and run it hard if all seems well offer him what your willing to pay and then fix it up, the wireing must be fixed asap that thing looks like a fire waiting to happen.
01-02-2009, 11:55 PM | #10 |
FAIL! find yourself a clean 240sx and work it up from there. I will never trust anyone that has done an engine swap, unless I know the guy before hand.
Steve.
S14 326 whp, 311 tq @ 15 psi HKS F-CON V-PRO |
01-03-2009, 06:22 PM | #11 | |
95 240sx RB20 415whp 91 Nx2000 VVL yo |
01-04-2009, 01:22 PM | #13 |
Crank triggers are more direct and more accurate than CAS. The more direct information about where the piston is located the better. Between crank flex, belts stretching and tension being set right, cam bearings. while all might have tight tolerances there's still play and add them all up and you have some partial inaccuracy.
