'Bout Damn Time Build Thread - Warning, Pics Inside.
So this project of mine has been going on long enough. Figured I'd better get it done and on the road. Problem is, if I keep stopping to wire wheel the nuts and bolts, Ill never finish!
On with the Pics... After Moving to the house. JDM S14 brakes, can you say 30mm. I knew you could. The shop boy at work (AKA my son Duncan) Prep with the engine out Primer... Ive got Pics of the Sealer, but cant find em.. On with the Paint, and clear!! |
Hold on, theres more...
Ive had that gallon of color for almost a year now. Always planned on painting it Diamond Graphite! Starting reasembly. Changing Fuel pump... Old Stocker New 255 Walbro Parts yet to be installed. |
I'm not sure why the first image is a link in my view. Let me know if any of you viewing this post see the same, and I'll try to figure out whats up.
Ok, since I have an audience... More Pics!!! The CS downpipe is pure art. Since I have S14 spindles for S14 brakes, I need....S14 ball joints! Taking off T25 New -4 oil fead line, and pressure restrictor/filter for upcomming S15-R T28 |
In keeping with the holliday.
The rest of the car is still stock red...( I hate red!) The entire rear suspension sub assy is out of a 92 R32 GTST. Thats how I got the rear five lug and big brake swap done all in one shot. |
Heres a couple of shots of the car when first started.
Not much progress tonight. A lot of cleaning. Put the crossmember and front suspension back on. Sanded and buffed out some runs in the clear. The lackeys helping me clean parts MMM wire wheel + nuts and bolts = Shiney Putting the steering rack back in with the new hard bushings Me holding my end up Nice and clean Ready for new struts to show up, and the spindle to be put back on. Tomorrow I will post the pics of the turbo install Last edited by RPS1392; 03-18-2008 at 06:59 AM.. |
#19 |
![]() Join Date: Nov 2007
i just bought a rebuild kit today and seeing you said the rebuild kit or rebuilding in general was misleading, i was just a little curious. how so? and how much for the kit?
#21 |
![]() Join Date: Mar 2007
Build is looking great.. Nice color's and nice choice with the hicas rear end... I also like that you let your son help... Get em started early so that by the time he's your age he will own u.. haha... Nice build
Obliterate |
#23 |
Yes, it is. I'm not crazy about the whole rear tie rod setup. Ive been thinking on fabricating up a set of links.
I looked at the spindle, and it seems I can just press out the tie rod end, and replace it with a bushing. |
#24 |
Ok, some more pics on the turbo install. I'm going to test a couple of links to photobucket to see if I can get them to function.
A little of this goes a long way to keep parts from becomming unattached. Installing the S13 adapters. Installing the CS lines Had to adjust the actuator rod so it wouldnt come in contact with the line. Before: After: Turbo is mounted. Glad I didnt do this after the engine was installed. |
#26 | |
EDIT: I have confirmed that each 1st pic conforms to the proper format. Not sure why each pic after the first works. Maybe one of the moderators could help. Last edited by RPS1392; 03-18-2008 at 08:12 AM.. |
#28 |
![]() Join Date: Jan 2005
Nice build thus far. You installed this line incorrectly though. You could have left the wastegate bar as-is, used the straight end on the turbo, and used the 90 at the block. It looks like you will be stretching the hose, the way it shouldn't in order to fit the hotpipe outlet. Won't fit either way... Fits Carlos |
