Old 04-22-2014, 04:35 PM   #1
vipergtsr1000hp
vipergtsr1000hp is an unknown quantity at this point
clutch spring fell off?
Hey guys, I went to start the car this morning. Started fine. Tried to put it in gear and it wouldnt go in. I checked the master & slave cylinder. Both good. Adjusted the pedal to see if it will do any good, but nope. For some reason the clutch doesnt go all the way down sometimes. I know theres no air in the line. Could one of the springs from the clutch fell off?
Thanks.
vipergtsr1000hp is offline   Reply With Quote
Old 04-22-2014, 05:03 PM   #2
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
-Jack up Car
-Get under car
-Pull off the the shift-fork dust boot off the bell housing of the car
-Shine flash light into the hole
-Have someone push the clutch pedal in the car
-Observe the movement of the clutch fork/slave cylinder
A popped clutch spring can cause this issue, but eliminate the low hanging fruit first
Ilya is offline   Reply With Quote
Old 04-23-2014, 12:17 AM   #3
zerodameaon
zerodameaon's Avatar
Did you break the clutch fork?
Need to adjust your idle?
#/f/s-chassis/395413...-pictures.html
Old 04-23-2014, 02:16 AM   #4
Jeff Jones
Jeff Jones's Avatar
Jeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of light
They can brake when racing. If the clutch pedal feels good and moves it's full motion, the pilot bearing could be stuck (frozen). Only way to fix it is to pull the trans.
Jeff Jones is offline   Reply With Quote
Old 04-26-2014, 01:14 AM   #5
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
It's not terribly uncommon for a clutch spring to pop out of place and get wedged in. Basically matches the symptoms you described.
Old 04-26-2014, 02:24 AM   #6
polar951
polar951 is an unknown quantity at this point
I've had these same symptoms. Turned out my OEM clutch had enough of abuse and decided to spit two springs out of the plate completely.
polar951 is offline   Reply With Quote
Old 04-30-2014, 10:12 PM   #7
vipergtsr1000hp
I went ahead and dropped the tranny. Found out one of the springs fell off and was sandwiched in. Clutch had over 30k miles and had lots of life left. Never buying an EBAY clutch again. Flywheel was fine thankfully. Put a brand new exedy clutch and now everything is good for now.
Old 05-01-2014, 09:29 AM   #8
brndck
brndck's Avatar
There's your problem, right there.
Old 05-02-2014, 01:38 PM   #9
808drft
808drft is an unknown quantity at this point
I had one of those springs fall out of my spec stage 2 clutch before. I just removed spring and put it back together. Those springs are only there for vibration dampening when releasing the clutch. Never had a problem with them missing.
808drft is offline   Reply With Quote
