s15 turbo on a s13 sr
I have a 180sx sr20, and getting a s15 turbo. Maybe im just over-thinking this, but would i need like a "oil restrictor" or something along those lines for the turbo?
im just thinkin' that with it being ball bearing it wouldnt need as much oil as the sr would be trying to push threw. im sure someones done one on here,.. post up
cONtRol FReAkS |
![]() Join Date: Sep 2006
Trader Rating: (-1)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: -1 reviews
What other mods do you have? List everything that you've done so far. It's not a great idea to say"let's just slap a turbo on". There are different "S15 turbos" also.
I'd warn you now that posts like this make you cannon fodder for people here. Prepare to get a few people telling you to search. If I were you, try to do some research and post what plan of attack you are approaching. People will be able to help you better when more information. |
![]() Join Date: Mar 2006
Agreed. Just order some Earl's turbo lines and an oil restrictor. I forget what size...do some searching.
![]() Daily driven |
ive done some researching, and the people i saw that did run a t28 havent put any restrictor on,.. and said theyve had no problems, so it just kinda stumps me. I dont have alot of free time, so i cant sit on teh interwebs and do as much research as i need to tho... so ,. sry bout that guys...lol
im just stock now, with FMIC, but i got a winter build going, and will be installing: -t28 -fuel rail -nismo 550cc injectors -aeromotive FPR -Q45 maf -cometic headgasket - maybe solid lifters ,... and thats about it engine wise,.. thanks for the help guys
cONtRol FReAkS |
![]() Join Date: Jan 2007
Found this by searching and am not creating a new thread.
Does the S15 Ball Bearing Turbo require and oil restrictor? From searching I've determined yes it does. It requires a restrictor with hole size ~.03" My tuner is telling me the turbo has a built in restrictor. Is this true? Question 1: Does the S15 turbo require an oil restrictor? Question 2: Does the S15 turbo have a built in oil restrictor in the CHRA? Last edited by Moon Ill; 05-07-2010 at 12:21 AM.. Reason: too many 0s on the hole size. |
![]() Join Date: Feb 2007
actually not exactly. for s14's and 15's the restrictor is on the bolt of the banjo fitting on the feed line that threads into the motor. and just to confirm what was said above. all gt ball bearing turbos use a .03 restrictor. ball bearing turbos need VERY little oil to lubricate as the cooling is done by the water lines so pumping to much oil into the turbo will only cause unwanted pressure and could blow the seals.
#13 | |
I called JGY and they said the .044 was what Garrett sent them for all the ball bearing turbos they sell.
But even Garrtts own site says a MINIMUM of .040" Quote:
![]() Join Date: Feb 2010
ya installing a s15 turbo i beleave when i did it many years ago i needed to reclock the elbow and i bought new lines. you can bend the s13 lines but its not a good way off doing it
i bought a gt2871r the restrictor fitting came on the turbo when i got it, i figured it'd need to be on the block to the line but figured that'd work too.
...and everything needed to be reclocked just to save you time from taking the whole manifold and turbo off and apart 3 times,....lol just make sure the oil dump is on the bottom, cuz when i just clocked the compressor side the dump was facing the block. just some shit i ran into,. hope it helps
cONtRol FReAkS |
