Old 05-30-2009, 10:33 PM   #1
angelom88
Banned from the Marketplace
Trader Rating: (-1)
angelom88 is an unknown quantity at this point
Feedback Score: -1 reviews
s13 tranny re-install problem
hey quick question i just installed my new clutch and i flywheel but the tranny does not want 3 go back in, does anyone noe something i dont noe, any help or any websites someone might noe thanks
angelom88 is offline   Reply With Quote
Old 05-31-2009, 01:16 AM   #2
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
your going to need to rotate it a bit to put it in, spin it clockwise then bolt it in to close the gap
supreme_1 is offline   Reply With Quote
Old 05-31-2009, 02:30 AM   #3
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
you have to line it up properly because of the spline. a lot of people have bad luck with trans. installs because they just keep trying to jam it in.
do what supreme said and try turning the trans. while putting some force so that it slides in.
some folks get lucky (myself, first time was the charm) while others it takes several tries and a few headaches.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 05-31-2009, 06:58 AM   #4
yokotavia
yokotavia's Avatar
yokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enough
Send a message via MSN to yokotavia
yeah just sit under it holding it up there trying to shake it violently for a few minutes at a time and it should go in as long as u aligned the clutch properly
Banana boat chronicles
yokotavia is offline   Reply With Quote
Old 05-31-2009, 07:15 AM   #5
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
I always un-bolt the motor mounts and jack the motor up, the trans goes right in without rotating it.
HYPNOTIK is offline   Reply With Quote
Old 05-31-2009, 10:34 AM   #6
yokotavia
yokotavia's Avatar
that could work too, by jacking up the front of the engine to "tilt" it back
Old 05-31-2009, 11:03 AM   #7
gunmetalr32
gunmetalr32's Avatar
gunmetalr32 is on a distinguished road
thats what i do too..
NEED S14 KOUKI VALANCES, S14 NAVAN SIDE SKIRTS, S14 KOUKI OEM JDM LIP HIT ME UP!!
gunmetalr32 is offline   Reply With Quote
Old 06-05-2009, 04:50 PM   #8
angelom88
Trader Rating: (-1)
yea imma try that tomorrow then it has been raining all week and finally tomorrow it will stop. i found a forum on nico and some guy said 2 unbolt the cross members and do this and that and felt like dieing.
Old 06-05-2009, 05:44 PM   #9
djcobra
djcobra's Avatar
djcobra is making a name for him/her selfdjcobra is making a name for him/her selfdjcobra is making a name for him/her self
Have someone tilt/push the engine from the front, that should give you enough angle/room to push that sucker of a tranny in. That's what we did when we installed my tranny back. No need to unbolt the engine mounts, there should be some flex heck I even have NISMO mounts installed and we were able to tilt the engine back a little good luck!
Steve.
S14 326 whp, 311 tq @ 15 psi HKS F-CON V-PRO
djcobra is offline   Reply With Quote
Old 06-06-2009, 06:48 AM   #10
angelom88
Trader Rating: (-1)
Yea I am starting 2 think it is my clutch, because I got a 6 pluck and I was using the clutch alignment tool and on the stock one I had before goes in ever easy and smooth but the new one (spec) is a tighter it does go in just not as easy as the oem one
Old 06-06-2009, 07:39 AM   #11
angelom88
Trader Rating: (-1)
O just more thing, I used the starter bolts (because they are longer than the other tanny bolts) and I used some washers and I impacted that tranny in. it went from having like a 2-3 inch gap to now it only having like a 1/2-3/4 inch gap, I had tried 2 tilt the engine up but it hadn't worked for me, so today around 3 o'clock imma try again, if nothing I'm just going to take out my tranny and engine swap my other ka motor slap on my t04 turbo setup and call it a day, well my weekend but we see
Old 06-06-2009, 11:22 AM   #12
Jonnie Fraz
Jonnie Fraz's Avatar
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Send a message via AIM to Jonnie Fraz
This might sound stupid, but when I was doing my first tranny install I was having a hell of a time, then I jacked up the rear of the car to make it level. The tranny slipped right in.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 06-06-2009, 09:33 PM   #13
redsx13
redsx13's Avatar
redsx13 is an unknown quantity at this point
noooo, dont do that! obviously the splines arent lineing up. If you force it you will break something.
redsx13 is offline   Reply With Quote
Old 06-07-2009, 10:05 PM   #14
Shadowhunter
Shadowhunter's Avatar
Shadowhunter is an unknown quantity at this point
Force is of little use where wisdom is called for. Don't try to force the tranny in there obviously if it's not going in then cramming it in there is just going to make shit worse. Use your brain and your hands that you were given and work that thing in there twist,wiggle and uh well you get the idea.
Shadowhunter is offline   Reply With Quote
