![]() Join Date: Aug 2004
![]() ![]() ![]() Feedback Score: 9 reviews
No brakes
I just completed a Sr swap an don't know if I hooked somehting up wrong or what. I have no brake pedal its not stiff or anything, theres nothing to it. When I push the brakes at idle it will make the car stall. I have the master cylinder hooked up to the intake manifold.
a silvia
![]() Join Date: Dec 2002
Sounds like the check valve is either backwards or defective. Check it and see.
![]() Join Date: Apr 2004
The one-way check valve goes between the booster and the vacuum source. It only lets vacuum go one way and not the other = one-way check valve.
Follow the FSM diagram to test the one-way check valve. There is a picture of a guy blowing and sucking on the valve. Then check for vacuum leak in the hose itself, or possibly the booster connection. |
