Old 04-27-2007, 11:51 PM   #1
az_240
az_240's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
2 way differential whine around 45mph... Anybody else?
I've got a 2 way cusco type MZ diff that will whine from about 45-60mph.
It goes away but then makes a louder whining sound around 80mph.
I put some shims around the diff bushings to make them nice and tight... but I dont think that alone will create a whine.
The guy that had the diff before me claims he never had any problems with whining from the diff at all...
I have dropped this diff 3 different times now and tried bolting it on different everytime with no change.
I also have stock suspension besides a ST sway bar and subfame collars.
Any help is appreciated.
Thanks
Old 04-28-2007, 12:11 AM   #2
Dousan_PG
Dousan_PG's Avatar
Dousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfectionDousan_PG is close to perfection
no sir
quiet as can be!
your ring gear might be going...
Aaron
Pink GodziRa
www.geocities.com/pink_godzira
Dousan_PG is offline   Reply With Quote
Old 04-28-2007, 01:09 AM   #3
az_240
az_240's Avatar
Trader Rating: (41)
I inspected everything inside the diff housing... everything including the ring gear looked fine
Old 04-28-2007, 01:11 AM   #4
20 til 3
20 til 3 is making his/her stupidity well-known20 til 3 is making his/her stupidity well-known20 til 3 is making his/her stupidity well-known20 til 3 is making his/her stupidity well-known
what fluids are you putting back in it?
20 til 3 is offline   Reply With Quote
Old 04-28-2007, 01:18 AM   #5
az_240
az_240's Avatar
Trader Rating: (41)
redline.... whatever is recommended.... i think its 75w90 or something.... with the ford friction modifier.
At first it had a thicker oil... redline 75w140 iirc
Old 04-28-2007, 01:26 AM   #6
20 til 3
so you went from a thicker oil to a thinner? imo i think you might want to run the thicker stuff again, i'm no expert but process of elimination would come into play before spending a bunch on a new diff
Old 04-28-2007, 01:46 AM   #7
az_240
az_240's Avatar
Trader Rating: (41)
it made no difference what oil I used.... still made the same whine
Old 04-28-2007, 01:48 AM   #8
Dousan_PG
Dousan_PG's Avatar
pinion bearing or output bearings could lead to whine
Aaron
Pink GodziRa
Old 04-28-2007, 02:00 AM   #9
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
if you don't fix it, it will get worse and go boom. At which point you will wind up with a possible jacked ring and pinion and chunks of metal floating in your diff case. Which is not good for the clutch pack.
New Video
Buy my mounts!
Old 04-28-2007, 02:46 AM   #10
az_240
az_240's Avatar
Trader Rating: (41)
^exactly why I want to figure out what it is.... the whining itself I can take i just dont want to ruin my $800 diff.
Im gona have a chat with the mechanics at my work tomorrow and see what they say
Thanks for the replys
Old 04-28-2007, 07:10 AM   #11
scottie
scottie's Avatar
I had the same thing happen to mine. The tooth gap was not correct. There is supposed to be a specific amount of "play" the diff is suppose to have. You should be able to turn the input shaft (driveshaft) and the output shafts (axles) and there will be or should be some play before the teeth catch. It its off by even the smallest of margins, your diff will whine. I would check that if i were you.
Scott
Old 04-28-2007, 08:09 AM   #12
Dousan_PG
Dousan_PG's Avatar
get another open diff and swap the lsd
see if that fixes it.
cost is nothing
time is maybe a few hours.
Aaron
Pink GodziRa
Old 04-28-2007, 10:39 PM   #13
az_240
az_240's Avatar
Trader Rating: (41)
I was gona do what Dousan suggested but I talked to some mechanics today and they said more than likely it is because of what Scottie is describing.... the diff is not configured correctly inside the housing and the teeth are slightly off....
Im gona drop the diff again and put some dye on the teeth to see how the mating pattern looks....
Then Im going to try calling some off road shops to see if they can help me since the transmission guy at my work will be busy for a while.
Thanks again for the help!
Old 04-29-2007, 10:59 AM   #14
!Zar!
!Zar!'s Avatar
So, you bought a diff, tossed it in, and didn't check your backlash?
Uuuggghhh
Scottie is right. Since Scottie is right, Dousan is starting to be right being as how you are in the process of destroying your gear. You need a dial indicator and the dye to get your diff the way it needs to be. To adjust the backlash, you'll need shims. To either raise or lower the pinion untill it's where it needs to be. Being as how you are hearing a whining, it's more than likely too tight. So you might not need to buy any shims.
Either way, drive the car only to the shop.
Old 05-01-2007, 04:38 PM   #15
az_240
az_240's Avatar
Trader Rating: (41)
mechanic said it wont do anything bad to the diff... just an annoying sound.
Old 05-01-2007, 05:20 PM   #16
Dousan_PG
Dousan_PG's Avatar
hahaha
great mechanic!
Aaron
Pink GodziRa
Old 05-01-2007, 05:31 PM   #17
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
LOL.
That backlash issue will kill the diff.
All you need is right sized shims and someone who understands diffs.
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
