Pbm Cobra downpipe torque loss
I am contemplating buying a Pbm cobra downpipe for my sr but am second guessing myself because I have heard that you lose torque. Does anyone have any experience with this?
I just put one on my SR and I haven't notice a difference? What's the 'science' behind this theory...?
My friend used a Cobra styled pipe it didn't last long, and the tuner didn't called it. That was the first and only DP that I seen crack. Not sure about the torque though. Im sure more people have had success but the one piece doesn't suit me. Also is your not extremely low what is the up side?
![]() Join Date: Jun 2003
Trader Rating: (129)
ive been running the same "cobra" downpipe for years with no downside. better clearance underneath, no more blown out downpipe gaskets, i've encountered zero downsides to it.
who told you you "lose torque" using this type? did they have before/after dyno graphs to show proof of this claim? |
That's what I'm saying...I just replaced all my fucking gaskets and the thought of avoiding that altogether sold me on the Cobra Flex.
Are you using solid mounts?
#8 | ||
All in all thanks for your input. All of you. If mods want to shut this down they can |
it was meh who said that. i went from a tomei blitz dp set up to cobra and noticed the difference. i have a decent engine set up i've been running for years now, but i've been using cobra for a few months now and to be honest the clearance alone is worth what ever numbers its giving me also not having to tighten my outlet bolts every few months is really nice.
Some black guy who lurks zilvia. |
#10 | |
![]() Join Date: Jun 2004
Trader Rating: (73)
So he was using a PBM DP or not? The upside to using this pipe is the flex section is in the vertical section instead of the horizontal section. I've seen dozens of flex sections on other DPs shredded because of low ride height.
#11 | |
i'm on nismo mounts, no flex section anywhere in my exhaust. i don't crack manifolds, blow out gaskets, or have any other issues with my setup.
mine is this style Quote:
me to i had the car dyno'd with the tomei blitz set made 320 whp around 312 wtq cobra pipping seems a little smaller then the blitz.
i like my cobra. not sure if they clearance was any better than the solid down pipe i had on there before, but at least I wont have to replace that gasket as often.
![]() Join Date: Oct 2008
Trader Rating: (28)
![]() ![]() ![]() ![]() Feedback Score: 28 reviews
For you peeps running tomei expreme manifold on your sr, what dp are you using with that? Sorry, didn't mean to divert the subject. Figured i'd ask since we were on the subject of downpipes. I wanted to run the pbm cobra pipe but looks like the only way to run it with the tomei manifold would be to modify it..
#17 |
![]() Join Date: Jun 2011
You won't feel a torque loss
And to people with gasket/cracking manifold issues: tack weld the nuts to prevent them from backing out and blowing the gaskets. and stick with the oem cast, manifold unless you are going larger than t2, and you'll never have cracking issues |
#19 | |
I said styled as I didnt want to imply I was bashing PBM.
#20 | |
Trader Rating: (131)
I ran a Parts Shop Max Cobra downpipe with Cusco engine mounts for three years and about 19k miles or so. I never had an issue with cracking or blown out gaskets.
#21 | |
AFC #1
![]() Join Date: Oct 2003
I would like to know what the OP was using before the PBM Cobra. Stock cast iron outlet?
I assume this is a seat dyno comparison. I cant figure how you would get a loss post turbine unless the pipe was so insanely big you were getting stagnation. Which 3" is not big enough to cause. Unless a dyno sheet is shown, I chalk it up to smoothing out the power band. Loss in surge feels like a loss in power. When you actually gained power. Quote:
1) The metal is too thin or low grade. 2) No flex joint and probably no transmission brace ether. The whole exhaust system is swinging back and forth from the turbo mount. Twisting the up pipe portion of the cobra. Ultimately you can't knock on PBM or the "style" when you are using a clone.
#22 | |
Trader Rating: (28)
Thanks for chiming in. So were you able to make the pbm cobra work with the tomei manifold with just a bit of brute force? I want to run this setup on my s14 with s14 sr... |
#23 |
Yep, it wasn't bad at all. A portion of the elbow was contacting the transmission. Heated it up and gave it a few hits with a ball peen hammer and that gave me the clearance I needed. I am sure it all depends on your engine and transmission mounts to some extent. This was with Cusco solid engine mounts and a NISMO transmission mount. It really wasn't too bad at all though!
#24 | |
![]() Join Date: Dec 2012
![]() ![]() ![]() Feedback Score: 3 reviews
Whalen's Speed R&D - IG - @MachinegunSquad - www.whalentuned.com |
#25 | |
Trader Rating: (28)
P.S. your blog awesome, inspires me to get mine going... ![]() |
#26 | |
It did have a transmission brace, but no flex, the car had ever solid mount and bushing made and was trashed on the road and track. Bolts, would come loose like it was cool. In Japan not may clones around, Im pretty sure it was a legit D-max produced. Random failure, so I won't knock it, and as I mentioned I'm not implying PBM is a bad product.
#28 | |
![]() Join Date: Oct 2011
![]() Feedback Score: 27 reviews
IG @jerry_beans_ |
#29 |
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() Feedback Score: 7 reviews
Reviving an old thread. i have a pbm pipe for my sr20. I remember the pbm folks told me to only use a bottom mount exhaust manifold for alignment with the pbm cobra pipe.
Does anyone know any aftermarket brands of manifold that they've tried that fits perfectly with the pbm pipe? I've heard the tomei bottom mount doesnt line up well.. Is stock the only option? |
#30 | |
Trader Rating: (73)
