![]() Join Date: Dec 2001
Anyone running RB20/25 series turbo on their 240?
I am just curious to how this turbo performs. I am actually going to put it on my MR2 turbo ( 2.0L ), if it doesn't work out, i'll put it on my SOHC s13.
here's some pics http://noclownz.dnsalias.net/newturb...o/DSCF0263.JPG http://noclownz.dnsalias.net/newturb...o/DSCF0261.JPG http://noclownz.dnsalias.net/newturb...o/DSCF0259.JPG Here's some info I gathered on the turbo: Car of Origin: Nissan Skyline R32 GTS-t Engine: RB20DET ECCS (silver rocker cover) Flange: Four bolt T3 style Max. Power Rating: 160kW Max. Boost: 1.2bar (17.4psi) Cover Size: AR not identified Comments: A big step in the right direction from both Nissan and Garrett. A truely nice turbocharger, complete with modern aerodynamics and ball bearing construction. It's a perfect choice to get the best from an internally stock, standard injector/management set-up. On a CA18 with a custom manifold, they are really good things. Cost: Reasonable, with some examples floating around the importers for as little as $400. You have to be quick thoughm as they tend to sell fairly quickly. Rating: Four out of five. Car of Origin: Nissan Skyline R33 GT25-T Engine: RB25DET Flange: Four bolt T3 style Max. Power Rating: Approximately 185kW Max. Boost: 1.2bar (17.4psi) Cover Size: AR not identified Comments: The big daddy of the range makes the RB25 turbocharger good for almost any mild six-cylinder application. Sparkling boost response in the low-rpm range and a reasonably hard-hitting top end make this the most common upgrade found on the RB20DET. It's highly recommended. Cost: Being very difficult to get hold of makes them highly variable in price. Sometimes about $700, sometimes more. Rating: Five out of five. |
#3 | |
