a/c condenser
so i am wanting to take my a/c out on my ka24de and the belt goes to the a/c condensor to the crank then to a idler pully do i still have to have a belt on the idler pully to the crank?
![]() Join Date: Dec 2002
If you have a belt on your A/C condensor, you have a serious problem.
There is a belt on the compressor though. And common sense would tell you if you remove the compressor, you can remove the tensioner pulley, bracket, and belt as well. But that would be way too easy to figure out it seems.
Reading shouldn't be that hard. Neither should common sense. If the compressor is removed, the belt no longer serves a purpose. Period. In that case, anything that's not directly related to the engine is also no longer needed. So as I said directly above you that you failed to understand, the pulley and compressor bracket can both be removed. They don't do anything once the compressor is gone.
