I am need of the two small steering rack hard lines. These are the two lines that connect to the pinion and then go into the rack. I'm not sure there's a difference between the SOHC hard lines and the DOHC hard lines but just in case, I am using a steering rack from a DOHC S13. The lines on the rack I have got kinked at the junk yard when they picked the car up with a forklift to take the rack off.
Here's a picture for reference just in case someone is confused as to what part I need.
Thanks guys!
