![]() Join Date: Feb 2009
OK should be simple but I just dont know where to look.. The bell the dome light and the seat belts dont move when the door is opened I bought the car like this and would just like to get it to work again... the dome light works but only when put to the on position so thats why i believe it is just a fuse or somthing but not sure where to look please help.. thanks
well its both doors. does anyone know if there is a fuse for? there is a fuse that says electronics thats a 10a that is missing in the box next to the clutch. I did put 1 in but nothing changed that I know of.
![]() Join Date: Oct 2006
There is a fuse that causes this problem when it blows. It's been a while since I had a hatch, so I can't remember which fuse it is, but I blew that fuse more than once. Get out a test light and just check all the fuses, unless somebody on here can chime in with which fuse it is.
ok so here are some pictures of what i see so far this is the only plug that is unplugged not to sure were it goes but its routed toward the fuse box so i don't know looked and looked and couldnt see any unplugged connectors.
![]() Join Date: Dec 2002
I really hate you now. Nothing is unplugged. That's the CONSULT port.
Buy a new clutch pedal bracket. $30 at the dealer.
Well since you seem to know so much why don't you tell me what you would do to stop all the funtions that happen when you open the door. Seat belts, the bell, and the dome lights.
Oyea I love HATERS thanks. |
#17 |
![]() Join Date: Jun 2009
OK. Grab a FSM and go to electrical. Find the circuit that regulates power to the dome light and the switch that comes on when the doors open. Follow the diagram back to the fuse. Replace Fuse. Done.
