![]() Join Date: Jul 2007
Trader Rating: (106)
KAde auto ecu questions
I am considering putting an auto ECU on my m/t KAde because I have heard that there are some benefits. I have HEARD:
1. the auto ECU has a higher rev limit (whoopity doo) 2. it has no speed limiter (def bonus) 3. it has slightly different fuel/timing curves which gives it a bit more power My questions are: 1. Is all or even any of this true? 2. Does anyone have dyno numbers with both ecu's if it is true? 3. Will I have to screw with the wiring a bit to make it work and if so what do I have to do? 4. Is there any difference in the performance of the different years of ecu's? I have done some searching and I cannot find any info on these questions. Your help would be greatly appreciated, thanks. |
all i know is that the automatic ecu got rid of the speed governor in my car (single cam). i can have the speedo needle pegged against the bottom of the guage cluster.
i cant confirm anything else.
cuz i dont give a fukk. that's why. |
Thanks, I was 99% certain that it would get rid of the governor. Anyone else? I know there are TONS of cheap asses like me that have done this or at least researched it.
![]() Join Date: Sep 2004
I've been running an auto ECU for a while now, and never noticed any more power. I did notice that the speed limiter is gone, itll rev a little past 7 if you want to, and the idle never dips when you push in the clutch.
------------------------- www.carolinanissans.com ------------------------- |
I found this with a little information on the subject that I hope helps you out. Hopefully someone can backup or refute the information;
#/f/showthread.p...light=auto+ecu
Sick Swapp-eR |
![]() Join Date: Jan 2006
yea ive heard using the wrong ecu is super beneficial.....
im actually going to have an incorrect tune done on my ecu so my car goes faster
ho ha ho chi chi |
![]() Join Date: Dec 2002
Speed limiter removal is the ONLY gain, there's nothing else different between the two.
As for fitment, any 91-94 will cross over. 95 and 96 can swap, and you can use a 97-98 if you repin three wires. All these will throw a CEL of course.
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() Feedback Score: 3 reviews
When I left my auto in it idled like crap with a manual trans but I think thats cuz I didnt wire in my neutral sensor... just get a tuned ECU if you wanna be safe and have no gov
Just talking about cars, one at a timeHorsepower sells cars torque wins races -Shelby |
Neutral switch doesn't matter, it's simply to tell the ECU gear position. I never had one on my last car when I rewired it, the new one used to be auto and doesn't have it either.
