Old 08-16-2013, 08:42 PM   #1
silviaNC
silviaNC's Avatar
silviaNC is an unknown quantity at this point
Turbo XS SR20det twin scroll manifold Review
Decided to try the new Turbo xs twin scroll T3 flange single 44mm wastegate. Here is their description:
XS-POWER
RELENTLESS TUNING
INTRODUCE
SUPER SR20DET -
SR20DET Twin Scroll Single WG Turbo Manifold Turbo XS-Power
Nissan SR20DET Twin Scroll Single 44MM WG Turbo Manifold
XS-POWER is proud to announce the release of the long awaited Nissan T3 twin scroll turbo manifold for your S13/S14/S15. This manifold is XS-POWER's answer to the most competitive market in the sport compact industry
. Combining the ultimate performance and durability with XS-POWER'S craftsmanship, this manifold can produce more power than any other configuration on the market and is sure to stand up to even the most demanding Nissan enthusiasts.
XS-POWER SR20DET Twin Scroll Single WG Turbo Manifold features:
•Thick wall stainless steel construction.
•48mm DIA PIPES!
•2.2MM WALL THICKNESS!! WILL NOT CRACK
•Precision robotic TIG welding.
•True twin scroll design spools the turbo faster with better VE and more power from idle to redline.
•Lifetime Warranty
First
WASTEGATE DETAILS:
•High temp based alloy is used for valve and valve housing will offer longer product life compared to competing designs.
•High temperature silicone reinforced actuator diaphragm.
•17-7 PH Stainless Steel actuator spring gives consistent pressure at high temperature, resist "relaxing" at temperature to 900F (483C).
•Stainless Steel is used for the valve seat, and valve bushing.
•All Stainless Steel hardware.
•Mating weld flanges are 304L
•Color anodized aluminum actuator (Silver, Red, Blue, Purple, Black).
•3 lower ports and two top ports for easy install, no need to rotate the actuator top at all, plugs included for unused ports.
•Ultra compact design fits in very tight spaces, the unit stands only 4.1" tall, more compact than any other 44+mm external wastegate on the market today.
•V-Band inlet and outlet make install easy, flanges and clamps are in the box!
first impression:
Manifold looks real good, welds looks well done as well
its sturdy and a lil heavier than a regular manifold due to the thick walls and 48mm diam runners. I will be installing the manifold and wastegate this coming week and will post fitment pictures as well as dyno sheets after everything is done.
currently running a GTX3071r twin scroll t3 .84 on a single scroll manifold. current setup is making 335/251 rwhp at 16 psi with
Built block
built head using hks 272 cams
silviaNC is offline   Reply With Quote
Old 08-16-2013, 10:50 PM   #2
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
Nice. Interested to see how your setup does with this. What mani were you previously using? And how much u end up getting this twin scroll for?
Luvs2slide is offline   Reply With Quote
Old 08-16-2013, 11:51 PM   #3
silviaNC
silviaNC's Avatar
Using a no name manifold atm. That's the reason why I can't go past 16psi. Boost will creep up to 23 psi. This is the current dyno sheet
I'm expecting faster spool and be able to go 28-30 psi with water meth kit. Its built for high boost.
Old 08-19-2013, 08:41 AM   #4
Sliderintrainin
Sliderintrainin's Avatar
Sliderintrainin is an unknown quantity at this point
Sr mani
I'm looking at this manifold as well. Where did you pick yours up from? Did you buy the manifold and waste gate together?
Sliderintrainin is offline   Reply With Quote
Old 08-26-2013, 10:04 PM   #5
silviaNC
silviaNC's Avatar
Seller currently have them on ebay. Relentless_performance.
Finally had some time to mock manifold, wg and the gtx3071.
44mm wg clears bmc, oil dipstick have to be relocated and vc breather need to be cut a lil shorter so it will have enough clearance with turbine housing and drain line will be real close to the wg runners so planning to do a slight angle 10an flange to have some clearance. As you guys can see also clears a/c line but strongly recommend to wrap it or slightly bend the line in compressor side. I will be getting downpipe done as soon as I get a day off. Cant believe how beefy manifold is compared with the no name manifold I had.
Old 09-10-2013, 01:13 AM   #6
marcone
marcone is an unknown quantity at this point
hey nice.. which turbo did you use? actually dw just realised u stated it.
however what housing did you use or did already come with a twinpulse housing??
marcone is offline   Reply With Quote
Old 09-10-2013, 01:45 AM   #7
marcone
How much does this manifold weigh?
Old 09-13-2013, 11:42 AM   #8
silviaNC
silviaNC's Avatar
I've been really busy at work but here is a small update. I pulled manifold off and cleaned runners and put high temp ceramic coat ( using correct baking procedures). This is a external gate manifold. Also installed coolant fittings and vacuum to wastegate.
Plan to use the xtra two threaded holes on turbo flange to make a small bracket to head manifold flange studs
Old 09-13-2013, 07:10 PM   #9
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
Interested on the outcome of this review.. Looking good so far!
SoCal KA24DET/KA24ET Owners
<< Join the FB Group >>
GroundPerformance is offline   Reply With Quote
Old 09-22-2013, 01:52 PM   #10
240knockout
240knockout's Avatar
240knockout is an unknown quantity at this point
How do you tighten turbo to manifold and tighten all the coolant line. I can't get to the rear on mine. Do u have to break turbo apart for installation ?
240knockout is offline   Reply With Quote
Old 09-22-2013, 02:04 PM   #11
silviaNC
silviaNC's Avatar
I installed everything yesterday. I bolted on turbine housing by itself and then chra with compressor housing together.
Old 09-23-2013, 08:09 AM   #12
Def
DEFSPORT
Old 09-27-2013, 05:09 PM   #13
Def
Weight? Anybody?
DEFSPORT
Old 09-28-2013, 06:41 AM   #14
AJZax
AJZax is an unknown quantity at this point
I was looking at this manifold as well. I'm curious as it holds up.
I'd be installing on pro-am FD/time attack car. Currently 3076r setup, later I'd just cut the manifold and weld T4 twin scroll flanged 1.05 EFR 8374. Trying not to go LSx! lol
What about using heat wrap?
Also are you making the downpipe?
www.ajdrift.com
Mansfield, A - 145
AJZax is offline   Reply With Quote
Old 10-02-2013, 05:37 AM   #15
silviaNC
silviaNC's Avatar
I'm not sure about weight. Probably heavy as a full race manifold. For those who asked. Pics of the re-routed coolant lines with thermal sleeves
Old 10-03-2013, 05:14 AM   #16
LED Sandwich
LED Sandwich is an unknown quantity at this point
Looks good mate, have you got this all up and running now then? If so what sort of power it it making? and at what rpm are you getting full boost?
LED Sandwich is offline   Reply With Quote
Old 10-03-2013, 06:42 AM   #17
PoorMans180SX
PoorMans180SX's Avatar
I take it the wastegate merge isn't divided all the way to the gate face? If it isn't, you're really killing most of the spool enhancing properties of a divided setup.
Old 10-03-2013, 03:40 PM   #18
240knockout
why 2 oxygen sensors?
also...which thermal sleeves are those?
Old 10-03-2013, 10:45 PM   #19
silviaNC
silviaNC's Avatar
Me and my buddy made the downpipe
I'm reaching full boost by 3900 rpms and over 450hp
Wrong, it is divided up to the wg flange
Havent hook up wideband to the standalone yet, so still using the stock (garbage I know)
From a local shop. I used -4an and bought 1/2 inch sleeves and they fit snug
Old 10-04-2013, 02:31 AM   #20
LED Sandwich
Oh right 3900 is not too bad then but quite a bit higher that a full race setup, a mate mine hits full boost at 3300, what boost pressure are you running, sounds like a really impressive setup do you have a dyno printout.
Old 10-04-2013, 06:41 AM   #21
AJZax
I'm thinking that 600rpm spool difference probably has other factors.
LED Sandwich, out of curiosity, what cams is your buddy running?
Also their piping (volumetric capacity of charge system) can make difference as well. You just have to remember the cams efficiency ranges are going to affect spool a bit. Top end response is also not noticed on dyno graphs. Intake style makes a bigger difference than people realize, and even intake filter. Not to mention "full boost" pressure. Intake manifold also makes a difference.
Is your buddy runing a 3" v-band? or a 5bolt outlet?
I'm not trying to be a smartass, just want a more complete comparison.
I'm very strongly considering buying this thing.
(When I had my ex. cam clocked all the way advanced I was hitting 22psi by 4300rpms gt3076r (440whp at 15psi), t.s. turbo non-t.s. manifold [lol pointless I know].
www.ajdrift.com
Mansfield, A - 145
Old 10-04-2013, 06:47 AM   #22
PoorMans180SX
That is pretty impressive, not many companies do that.
Old 10-04-2013, 06:54 AM   #23
LED Sandwich
Ill have a check and get back to you on that one. he has a trin dividae wastegate manifold which should make a little difference.
Old 10-09-2013, 10:10 AM   #24
LED Sandwich
Right i had an ask around and he is usng stock cams this was his spec. this was achieving 420hp and full boost by 3300rpm
Spec is:
Cp 9.0-1 pistons
Manley h beam rods
Chemically cleaned and lightly decked block
3 angle valve seat
Waisted standard inlet valves
Acl race bearings
Lightened and balanced bottem end assembly (crank,pulleys,flywheel,clutch)
Standard cams (for the moment) with cryo treated rockers and ras
Circuit sports billet fuel rail and sard 850cc injectors
Full-race twinscroll twin ext wastegate manifold
Garrett gtx3071 with full race twinscroll ex housing .71
Old 10-09-2013, 06:54 PM   #25
Kingtal0n
Kingtal0n's Avatar
Spec is:
Cp 9.0-1 pistons
Manley h beam rods
3 angle valve seat
Acl race bearings
Doesnt make sense. A stock cam with all of that? no. VE is not good enough to even make 350rwhp with a stock SR20DET camshaft, so no, no. (on pump gas)
That would be a record setting dyno graph if you post it.
On the other hand, I could see it happening at 33psi on E85 or C16 fuel, and 8,400rpm. But judging by the 850's I am thinking... no. not on a dynojet.
https://tinyurl.com/turbo240
Old 10-10-2013, 01:10 AM   #26
LED Sandwich
Its not on E85 or anything but our pump fuel is a little different. It will bemapped for 99 ron which is our premium fuel. He was looking into cams but said he was struggling enough to find tracks that were bug enough to run his current power on. a lot of the uk tracks are quite short ad twisty so you lose some advantage from high powered setups.
Old 10-12-2013, 11:39 AM   #27
AJZax
hmm I hit 26psi by 4500 rpms
singe scroll manifold lol with .78trim gt3076r.
You think there's enough room to fit in there with a torce and cut off the T3 flange and weld on a T4 t.s. flange? I'm looking at using it coupled with an EFR 8374 ext. wg.
Or Maybe 8374 IWG with full race IWG manifold. What you guys think?
(not tryign to thread jack ahah)
www.ajdrift.com
Mansfield, A - 145
Old 10-13-2013, 10:48 PM   #28
silviaNC
silviaNC's Avatar
Its kinda hard to believe he can push 420 on stock cams. Ajzax I don't think a t4 flange will fit. The is little to no room to valve cover
Old 10-14-2013, 02:06 AM   #29
LED Sandwich
Ill have another chack when i see him as the spec list was a couple of months old, but it was 420 flywheel horsepower not wheel, so i guess 390 ish wheel horsepower.
Old 10-15-2013, 02:20 AM   #30
AJZax
thx for the heads up on the valve cover clearance man!
I think I'll be running IWG .92 8374 EFR with full-race T4 twin scroll EFR IWG manifold.
This manifold setup looks sweet though! I may later upgrade to it on my daily with a 3071 twin scroll? Help fuel economy right!? Gotta get them MPG in the grocery getter S14!
www.ajdrift.com
Mansfield, A - 145
