One of my large ones blew tonight so I took it all apart in order to replace it, but I want to change all of them to avoid this again in the future. I tried looking up a sentras diagram but it seems different so my questions are does anyone know of direct replacements for any of these or do I just need to go to the store and make some stuff work?
Also known sizes would help too. I was thinking of replacing all the smaller ones with silicone hoses, like what I have on my breather tank, would that work ok? Possibly better? Extras Im also going to go to a s14 water neck and eliminate the lines behind the block so if anyone has any words of wisdom thanks in advance.
☆ Panda Pirates ☆ |
![]() Join Date: Mar 2007
just take a piece of each one and go to an auto parts store, buy extra of what size you need and buy new clamps! also ditch that fram filter asap it's made of paper
Obliterate |
![]() Join Date: Jun 2007
I redid all my under-intake hoses with 3-ply silicone. Ordered everything from www.verociousmotorsports.com .
![]() Here is what I ordered and the item #'s: Hose #1- 3/4" (item # VMSHSE3P-075-12-BLU) Hose #2- 1" (item # VMSHSE3P-100-12-BLU ) Hose #3, #5, #6 (AAC valve & throttle body coolant lines)- 5/16" (item # VAHSE3P-031-36-BLU ) The throttle body coolant lines are not completely necessary; I capped mine off. Hose #4- 5/8" IIRC (you may want to put a dial caliper on it to be sure)... As you can see, mine was in good condish so I left it. I tried other straight pieces of blue hose; but couldn't get them to connect to my satisfaction w/o kinking up. Your PCV hose is 3/8" (item # VAHSE3P-038-36-BLU ) The large air line from your cold pipe to your AAC valve is 3/4" (Same as hose #1 in your pic). Hope this helps. --Mike P.S. Great opportunity for some spring cleaning. Purple power, brake parts cleaner, elbow grease and a wire wheel will do wonders ![]()
Thanks for the help I got most everything bought today other than clamps.
One thing though, one of my smaller hoses I couldn't find a heater hose to match but I did find a fuel hose, will that be ok? (I know you cant use a heater hose for fuel but vice versa?)
☆ Panda Pirates ☆ |
You DID realize that they sell it by the foor, right? If you measure carefully & only get the amount you need, the pricing isn't that bad... I got way more of everything than I needed just to have extra on hand. They aren't cheap; but you can't go wrong with good quality silicone hoses... great for both longevity and aesthetics ![]()
you got all you need here :
sr20det silicone hoses | eBay I personaly buy from zenaracing : Silicone Heater Hose Kit Silvia s14 S15 SR20DET 200SX | eBay never been disapointed. |
Ya I did the same thing with the extended rear coolant line, definitely helps until I eliminate the whole rear part. Those eBay links are helpful, I paid more than that for reg hoses I bought at the part store :/ that's what happens when you don't have a daily and need to fix it right away though I guess..
Thanks for the help everyone.
☆ Panda Pirates ☆ |
Silicone hose are not a good answer. They tend to soften and then leak later. If you want all new oem hoses you can probably order them from Gspec.com Talk to Greg Vogel there. He deals with all these specialty items all the time. He will get them to you quick.
I absolutely hate silicone hoses and you definitely dont want those underneith hoses to leak on ya because good luck getting to them. Also suggest using the oem clamps as they are spring clamps that constantly apply more pressure and close as the hose softens and wears. |
Oh and you might want to clean up those pipes really good while your in there. Unbolt them all and clean up all the rust or youll be asking for another leak as well. Might want to stop using soo much water or only water. The pipes look horrible.
#12 | |
Also I run a Samco silicone radiator hose kit that I've had for just as long w/zero leaks. Here is the page for the kind of hose I use: Silicone Hose Couplers: 3 Ply Silicone Hose Sold By the Foot for Turbo, Intercooler and Intake Piping . Click the specs tab below. Feel free to check out their couplers too.
#15 | |
I drove my car for about 20 000km+, the only hose that has a problem, was the only one which is not included in the kit, and I used an OEM one, juste near the starter, I replaced it with a silicone hose that I had somewhere laying in the garage, no more problems from then....... Silicone don't burn as OEM ones, don't became hard with time like OEM ones..... the only thing you must be careful with, is that the connectors have to be totally dry when you use them, or they'll leak. |
#16 | |
Sorry, I won't have enough left over; and what I will have, I plan to keep.
#17 |
oh...
well i went through every item number you put up, and put them in the cart. total came out to be $63 ish. what else did you get? if they sell it by the foot, i should have plenty left over right? |
Probably not... but it depends on how you plan to run it. I bought 1 foot of 1", 6ft of 3/4", like 3-4ft of 5/16" & like 3-6ft of 3/8" . I would have to check my orders again to tell you for sure. Just remember, measure everything out, and buy more than you think you will need just to be safe and you will be fine.
#20 |
![]() Join Date: Jul 2011
I think most leaks on coolant hoses comes from over tightening. As long as you don't adopt the "keep tightening til it stops" method and apply some sense, your hoses should remain leak free.
#21 | |
![]() Not sure what you're trying to say here; and even though I don't owe you any explanations, I will try to explain one more time- I have about 6" of 1" hose left- not for sale. I have about 3 feet of 3/8" left, give or take... and I still need to plumb from the intake to the brake booster (across the rear of the bay). Whatever little is left will not be for sale. I bought like 6 feet of 3/4" hose, used to plumb the inner heater line in the pic I posted; I still need to plumb the heater core feed/return... plus THIS (Cold pipe to AAC): ![]() so YES, there is quite a bit more hose on that side of the bay than you'd think. There is NOT going to be much left over; and what little I have left will not be for sale. If you have any other questions; take it to PM.
#22 |
I would use nothing other than reinforced silicone hoses just as all my intercooler couplers are. But if you use just a worm drive clamp the silicone hose will still become soft over time and can leak. Ive seen this happen from Samco reinforced silicone hoses all the time. Best thing to use with those hoses are spring loaded t-bolt clamps. Then you will never get a leak.
I wouldnt use anything other than oem hoses under the manifold. Sorry thats just me. Again if you want oem hoses you can get them at gspec.com, just contact Greg and he can get them. Also the Sentra's fwd SR20 is completely different under the manifold. None of the hoses are the same. Sorry. |
#24 |
Just found out from a quick Google search. It controls the idle thru conditions like AC, lights, stereo etc turned on to keep the car from stalling. Apparently you can bypass it & adjust the throttle plate open for a good idle; but it may go awry as soon as you start turning on electrical stuff & loading down the engine. Since I am keeping my AC, and running other electronic goodies; I am glad I chose to keep it
#25 |
![]() Join Date: Dec 2011
Wish i knew those parts numbers, i just went to autozone and tried to find the closest looking one. When you put the clamps on make sure you angle it so you can tighten it when the manifold is back on, wish i also though about that .....
#26 |
No, the FIC valve controls idle when the A/C is kicked on. The IACV controls it all the time by the ecu, so in cold weather or when the engine is cold it bumps the idle up to 1200, then when warm knocks it down to 800rpm, It also keeps the engine from stalling on changes from throttle application to closed throttle as necessary. Its always working to keep as solid and steady idle as the ecu can.
You can run without it and adjust the throttle plate, i run no IACV and i have a nice steady 1000 rpm idle. However for a street car, you really should be running an IACV if you can. If its there, why not use it. Simple as that. One with idles much better than one without. Without especially when the engine is cold, you have to constantly play with the throttle to keep it idling well. Cuz it will want to die if you dont. |
#27 |
Hey guys first of let me say thanks heaps for all the replies so far all have been very helpful.
my problem is i have a leak in that iron heater hose there (2,4 attached to) i was wondering does anyone know where to get this part from? also how difficult is it to take off the intake manifold? i took it to a mechanic who said the leak was in the thermostat base housing and top housing so i replaced both of them but then when i started it up it was still leaking just as bad so i got some mirrors in there and saw it was this heater hose (i did the thermo from the front of the engine). any tips would be greatly appreciated. oh btw its a 1998 s14 200sx sr20. |
#28 | |
![]() Join Date: Jan 2012
