exsesive droppage?
Are there problems with dropping a large amount on full coilvoers systems? I'm talking about maybe a 3inch drop on a s13 frame. Can most middle price coilovers, like silk roads, spls, d2s, ... so on handle this kind of drop. I know there is the issue of bottoming out the car, but I'm used to driving extremely lowered cars.
![]() Join Date: May 2003
Coilovers like Tein HE (and possibly some of the ones you mentioned) have adjustable lower perches, so you can lower it as much as you want, and the suspension still has full travel. So you just preload the springs a little, then adjust the height with the lower perch...and aside from bottoming out or wheels rubbing the wheels well, the shocks handle it just fine.
- Brian
www.KA24DEvelopment.com |
#4 | |
![]() Join Date: Dec 2002
Those are cheap. The damper doesn't move. The spring does. You shouldn't bottom out the car with a manly spring rate. When the car gets lower the rest of your suspension arms will follow. This means that all of the arms are a bit out of stock geometry but nothing to worry about. Since the arms are all lower they WILL, I repeat WILL hit things.
AFC #1
![]() Join Date: Oct 2003
You'll start scraping various exhaust parts first on speed bumps. Then your aproach angle for ramps will change cause you don't want to rip off your front bumper.
The nice thing about coilovers is their ajustability. I can drive around all week up high to clear everything. Then drop it if I want to show off.
#9 | |
![]() Join Date: Jul 2003
Adjustable perches. Allow you to lower your car, without sacrificing shock travel. Meaning slammed car good ride. Shock body hits top plate? I dont understand. |
![]() Join Date: Jan 2003
dual adjustment (height) coilovers are best. Like outlined theres a perch and u can adjust height a little too by preloading. My silk roads are set to the minimum height drop, and that shit is still atleast like 1.75-2inch drop already. and the front is dropped liked 2 inches. and i think it can go about 1.5 more on the front, probably like 1.5-2 more on the rear. Tein lists their height drops min/max on front/rears. but the HE's and HA's are well priced and will drop low as hell.
#11 | |
And more preload can be added to adjust the handling..,or if you get it cornerweighed. But more preload does not necessarily mean better anything...FYI. - - - - - Unlike some "OBX" coilover sleeves, where you adjust the lower spring perch to drop the car, here you get full shock travel, and a REALLY low ride. - Brian
#13 | |
Ok then Im lost. I know that preload is basically, when the shock is fully extended the spring is not. The spring will never be fully extended it is alwyas under a load. I just don't know how you adjust this?
Ok there is a adjustable perch that allows you to change the height of the car by twisting it higher or lower. Then there is a lower perch that allows you to adjust the shock height in reference to the lower bracket. I'm not seeing anything that lets you adjust preload?
#20 | |
AFC #1
The lower perch adjusts the height of the car by making the total length of the shock body longer or shorter. See how the rear springs are the same length but, the one on the right's lower perch is lower making the total length longer. The one on the left will make the car lower but, they will ride the same cause the upper perches are the same.
#21 |
ohhh so the top pereches adjust preload and the bottom adjusts height. Are you only allowed the height adjustment till you hit the bottom of the rear holder there. That dosen't seem like much height adjustment on those teins. The jics above seem to have much more height adjustment. does it vary this much between brands. Also is it ever possibler to increase preload so much that the shock hits the bumpstop?
#23 |
does a ground control koni setup work the opposite way? Where you adjust the spinners on the gcs in order to raise the veichle? Also is adjusting the preload similar to adjusting the suspension's softness?
#24 |
Christ mang, go buy a book, read it, then come back.
#26 | |
2) Yes and no..it's not that simple. You need a tiny bit of preload ot hold the spring in place, so it doens't rattle or come off the seat. That's all you should be concerned with. More preloading can be used when cornerweighing the car, or to effectively make the spring stiffer. Either way, it's used for fine suspension tuning, not just a low ride. - Brian
#27 |
just know that lowering that low will screw up suspension geometry like others have said, so i'm assuming you don't plan to track the car, unless you get other adj suspension goodies...
btw, i love lowered cars, but hate driving them, so many scrapes on my car, not even funny... |
#28 |
I plan for now just to get coilovers and rear upper control arms. I plan on getting a medium range coilover. As you can tell, I know very little about suspension. Eventually in the future as I learn more and more I would like to get the extra bits needed and take it to the track.
#29 |
If you plan on taking it on the track and want to fix the suspension geometry check out splparts.com. They have all sorts of goodies that correct the change in geometry.
#30 | |
coils, tie rod, lca, ruca, tension rod etc etc... which in the end will lead you to most ppl who mod a lot -> being broke... |
