![]() Join Date: Nov 2003
Can someone with R33 calipers take some measurements?
I need 3 measurements for r33 gts-t calipers before I place my order for a set of wheels. I don't have the r33 gts-t calipers yet so I can't take these measurements myself.
These are for R33 gts-t calipers not the gtr brembo's. 1. Distance from rotor to face of caliper. GREEN LINE 2. Distance from rotor HAT to face of caliper. NOT THE RADIAL MEASUREMENT. RED LINE (1 and 2 measure along the same plane) If measuring while on the car it's a "LATERAL MEASUREMENT", if that makes sense. 3. RADIAL MEASUREMENT FROM CENTER OF HUB TO OUTERMOST POINT ON THE CALIPER. ORANGE LINE Thanks I greatly appreciate it! ![]()
![]() TougeHero.com l SilviaV8forums.com Last edited by 0100; 06-13-2008 at 01:15 PM.. |
From the actual surface of my rotors to the face of the calipers is 2 1/2 inches. I will need to take off my wheel to measure it from the hat.
Hope this helps.
KEEPIN IT REAL!
