![]() Join Date: Dec 2006
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
[Behind Horizon´s] 200SX S13 Drift Project...
Hello guys,
it is a pleasure to me to watch your great projects which gave me a lot of inspiration so i decided to give you something back. I like you guys over here at this board as some of you are very crazy, just as i am. I think its now my turn to inspirate you guys with my project and i want to introduce it to you, so enjoy it and write what you are thinking of it. History: I bought the car back in May '06 it is an '90 RPS13 200SX ,i bought the car without a engine but with a good transmission and a relative good overall condition. The previos owner ripped the engine out of the car for other purposes. On the same day i bought a totally damaged '90 S13 A/T but with an good 30.000 km engine in it which was replaced and completly overhauled by nissan. After we took the engine out of the damaged car and all the good spare parts we brought the car to the scrapjard, so i had one less SX in my garage. The project: The car is build up primary for trackdays (grip driving), especially for drifting and for the nicest and curvyiest streets in Black Forrest (Germany). Before we took care on the upgrading we first fixed all the damages 16 car years had caused. All rust was removed carefully and other little and big problem zones of the car was fixed. First i want to say that i want the car to be technically superb and want to save the money for expensive bodykits and rims for the first time. The engine is a full Stage III setup with some goodies i will concentrate on a very good torque curve and response and not on the peak horsepower. The important thing for me is to do as much as possible by myself and to be as creative as possible whether then spending a lot of money on expensive Parts. Actual Part list: Engine/Transmission/Exhaust: · Garrett GT28R Turbocharger · Steel braided hoses for turbo · CNC Turbo flange · CA16DE Inlet Cam · Z32 AFM + Tomei Z32 AFM Plug · HD Stage 3 Chip · 444cc GT-R Injectors · DensoIQ24 · Apexi Air Filter · Oilcooler Mocal 330mm 16R · RSPEC Boost Valve · HKS Style BOV · Jun Flywheel · Exedy Paddle Clutch · Adapterplate for Oiltemp/-press · SSA Manifold, Turbo ellbow, Downpipe, Catback, Flexpipe all in 3" · Exhaust insulting wrap · Walbro Petrol Pump · SSA RX7 Intercooler with Samcos · Upgraded watercooler + electric twin aircoolers · Greddy Oil Catch Tank + K&N · Nismo Transmission mounts · Nismo Engine mounts Suspension/Brakes: · Apex Performance Coilover Kit, 8 and 6 kg/mm spring rates · 17"x8,5" +30 CR7 Rims · Energy Suspension Polyurethan Bushings all round · Solid CNC Alu Subframe bushings · 350Z Brake System front + R33 GT-R Brake System rear Interior: · Sparco Full Bucket Seats · Sparco 3-Point Harness · OMP Corsica & Momo Boss · Nismo Shift Knob · Cusco handbrake drift Knob · Greddy 60mm EGT gauge · VDO 52mm Watertemp gauge · VDO 52mm Oiltemp gauge · VDO 52mm Oilpress gauge · VDO 52mm Bosst gauge Exterior: · Custom Red/Black Paint · Custom OEM Preface Front Bumper · Custom OEM Drift Hood · Custom Front Fenders with Alfa Romeo 156 Side indicators · Custom Decals (coming soon) · Painted back number plate holder · Complete Kouki taillight set Various: · Foliatec Super Dark Side Window Tint · Philips Blue Vision 4000 Bulbs · V2A Bonnet Holder Coming in 2007: · Nismo GT PRO TT 1.5 L.S.D · Uras NS-01 wheels · Ichiba 5-Lug Swap · Full Cage · Water Alcohol Injection · Custom Mapping · Strut braces · Anti Roll Bars · Rear Lower Control Arm Bar · Rear Toe Control Arms · Rear Traction Rod · Rear Upper Camber Arm · Inner and outer tie rods · Tension rods · and much, much more Last edited by Behind Horizon; 01-25-2007 at 12:48 PM.. Reason: optical improvement. |
mmmm I just sent some stuff to Berlin.
First of all the boring part, the parts:
Garret GT28R: Apexi + Z32 AFM: Jun Ultralight Flywheel: Exedy Paddle Clutch good for the lbs of a ~ 500hp engine: Better Inlet Cam for more mid-range torque: 350Z Brake System: (324x30mm) |
damn thats some money into that car...i hope to see the project come along....lookin good
My Feedback |
Custom Front OEM Drift Bumper:
Painted Number Plate Holder: Assembled the engine together: Washed transmission behind the selfmade Nismo Strut Brace. Instruments wait for their final check to glue them on. Modified Manifold: |
Here you can see my selfmade Airguide for the Oilcooler and my selfmade RAM-AIR-System
Assembled the engine to the transmission. You can see here how the intercooler will lay in the engine bay. It will be a V-Mount setup. Putting the engine to the place where it belongs: |
My Selfmade Airbox for the Raim-Air-System:
Custom fenders with Alfa 156 indicators: Sprayed the roof black: Test fitting my rims, the new coilovers are in too: |
We choosed to use an uprated twice as thick and with better rib design as the OEM watercooler, including 2 E-Fans and a thermoswitch.
(Actually swaped for a brand new unit as the old cooler was leaking) The finished V-Mount Setup, mention the very very short IC -piping My Drift Style OEM Hood with a air exit for the IC , ready to be painted black now |
The airbox and its mounting is finished now + painting the engine cam covers. The hood is painted now black and we are working on the air guide for the V-mount. Also we managed to get the battery in the boot. More pictures will be posted in one week.
Update: We changed the timing belt and the two rolls, also we put the CA16DE Cam in and checked/set the ignition timing. The engine is running fine and is making a very very insane sound. Also we relocated the battery to the boot due to place problems in the engine bay and weight balance. The battery will be covered by a box soon. (Its the old battery sitting there) The new water tank for the V-Mount Setup: The mounted boost valve and bov: The hood is now black: |
#17 |
Update:
The finished engine bay: One piece of the air guides for the V-mount setup.: lue Led's @ work, some Led's are not build in yet. My fire Extinguisher-System: This picture was taken after the first test-drive, the exhaust spit the complete back of the car black as you can see |
#20 |
Are you going to paint the fenders red? I haven't seen an s13 with the whole top part being black (roof, hood, and light covers). That's cool.
I actually like the front bumper, but mainly because it's functional + stylish. If it were on a semi-stock S13, I probably wouldn't put it on (personally). Good job on that hood too. Before I scrolled up and saw where you cut it yourself, I thought it was aftermarket lol |
#22 | |
But as the first german drift board opened a month ago i offered the guys to put a huge decal on it for promo reasons. I'll get a custom decal graphic soon which will cover the whole side of the car and it is looking brilliant. ![]() |
#23 |
![]() Join Date: Jan 2004
You almost killed my computer. Great frickin work but I honestly wouldnt expect 500hp. Not with that turbo/injectors. Hurry up and get out there with a camera. I want driving vids.
I'm from Florida so I'm probably a bit more strange than you |
#26 | |
I dont know how much hp my engine is producing but i guess about ~300 hp, as guys over here in europe have 280-300 hp with much less performance related parts in their CA18DET at Stage III. |
#27 | ||
#28 |
![]() Join Date: Sep 2006
Lots of your pictures are not working now, but from what i've seen, you've built an amazing vehicle.
loading HATERS.....99% ███████████████] |
#29 | |
#30 | |
