Old 11-14-2001, 09:21 PM   #1
240sxspeedracer1
240sxspeedracer1 is an unknown quantity at this point
Send a message via AIM to 240sxspeedracer1
I was wondering if anyone has encounered the same prob that i have.  My tail lights don't work.  Also, none of my side markers work.  And, one more thing, my lights inside where the rpm, and speedomoter are, doesn't light up either.  Once, i tried putting in a new fuse for the tail lights but it blew right away.  Is there anyway i can fix this or do i have to go to an electrician?
240sxspeedracer1 is offline   Reply With Quote
Old 11-14-2001, 09:28 PM   #2
gh6o6
gh6o6 is an unknown quantity at this point
have you done any rewiring or thought you "fixed" something or messed with wired because it sounds like thers a wiring problem. if you have like sick amounts of free time trace all the wires starting around the lights and make sure there all insulated and secure.
gh6o6 is offline   Reply With Quote
Old 11-14-2001, 09:29 PM   #3
gh6o6
another thing... are the sidemarkers aftermarket? if they are check the wiring on them first
Old 11-14-2001, 10:09 PM   #4
240sxspeedracer1
i havent done anything to the car.  I just got it like 3 weeks ago.  None of the lights that i described ever worked.  So, in answer to ur question, it is not aftermarket sidemarkers.  Everything stock.
Old 11-15-2001, 02:08 AM   #5
misnomer
misnomer's Avatar
misnomer has a little shameless behavior in the past
Send a message via AIM to misnomer
gotta be wiring, unless you're good you may want to have a mechanic check it out. Prolly a short circuit somewhere. Easy enough to fix, but you gotta locate the problem first <img src="#/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=':p'>
misnomer is offline   Reply With Quote
Old 11-15-2001, 10:01 AM   #6
gfisch
gfisch's Avatar
gfisch is an unknown quantity at this point
Send a message via AIM to gfisch
Not sure about on the 240's but on my mom's Audi, she had the same problem and it was because one of the lighbulbs wasnt right, the contacts for the bright and dim light for turning and braking were bad. Make sure all the bulbs are in tight, that they arent burned out, and that they are the right models.
Greg
'95 SE
gfisch is offline   Reply With Quote
Old 11-15-2001, 04:19 PM   #7
Guest
Posts: n/a
Well, here's a suggestion I wouldn't recommend, There's something called a smoke test. You just put something between the where the fuse connects' like a copper wire, something that won't burn, and watch for smoke, and there's your problem. I wouldn't recommend that, so just check all your connections and make sure they are all in there right.
Old 11-16-2001, 06:46 AM   #8
gh6o6
yeah it might just become the fire test and then youll be looking for the flames and then replacing stuff if you do take a video and post it so we can see you run circles around the car looking for smoke <img src="#/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
on second thought dont ruin you car. Dont use the smoke test (althought it would be funny)
