![]() Join Date: Jan 2007
![]() ![]() Feedback Score: 9 reviews
GKTech - Rear Subframe Slip-in Collars
The GKTECH rear subframe collars are used to eliminate axle tramp and to also tighten up the rear end giving more precise control of the vehicle under harsh driving conditions. - CNC Machined - 8 Piece Set Vehicle Compatibility: - Nissan 180SX - Nissan S13 Silvia - Nissan S14 200SX - Nissan S15 200SX - Nissan Skyline R32 GTS-T (2WD) - Nissan Skyline R32 GTR (AWD) - Nissan Skyline R33 GTS-T (2WD) - Nissan Skyline R33 GTR (AWD) - Nissan Skyline R34 GTT (2WD) - Nissan Skyline R34 GTR (AWD) - Nissan Cefiro A31 - Nissan RNN14 GTi-R Price: 49 AUD (approx. 42 USD) Shipping cost: From 36.36 AUD (approx. 34 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/rear...n-collars.html FAQ What’s the advantage of the slip in collars? The slip in collars sit above and below your standard subframe bushes and essentially compact them. This results in less movement of the subframe and eliminates axle tramp and increases stiffness in the rear of the vehicle. How hard are these to install? Installation is pretty straight forward and the slip in collars are as the name suggests, slip in. Installation shouldn’t take you longer than 45 minutes - 1 hour. Is there a noticeable difference in the feel of the car when driving around normally? Ie. any vibrations? If you don't already have coilovers and other noisy parts then you will notice an increase in NVH however if you're running coilovers, there's no notable difference. For any inquiries please e-mail us at [email protected]. |
