240sx too rich need help
ok so i have an s13 with a ca18det. i bought the car not running and a few weeks later i got it up and running. it idled a little rough and ran a little lean and when i stepped on the gas it would go a little rich. i figured it was the safc that need tuning so i took it to a shop for a tuning and they told me it was "broken" or defective so they disconnected it and only charged me half the price. the car idles really good the a/f ratio is at a 14.7 at idle which is good but when i step on the gas even the slightest bit it goes super rich and it doesnt not pull at all even when i hit boost. I dont know much about how my motor is built i mainly bought the car for a shell but when i got it running plans changed
so my questions are- Do apexi SAFC2`s go bad over time or was that shop just scamming me for my money? What is causing my car to run so rich i figure its either i have monster injectors or my ecu is programmed to dump a shit load of gas but if anyone else has any other suggestions they would help. me being only 17 you could consider me noobish |
Hello send me an inbox if you get this solve. I have the same issue. Its burning motor oil now. I don't know why. Is it the turbo or the TPS. I got it checked mechanics said its the TPS sensor. I have not get that fix yet but I'll do it real soon. My car just go so slow and i don't know why. Sometimes it goes fast but when i stop stepping on the gas it stops reving after 2 or 3
Sent from my iPhone using Tapatalk - now Free |
![]() Join Date: Mar 2013
its highly unilikely for an s-afc to go bad. however disconnecting it is a step towards the truth.
sounds most likely like a boost leak. check all your hoses and piping, and if you dont find anything, take your intercooler off and pressurise it in water to check for bubbles. |
| safc 2 |
