JZ swap cost stupid expensive
I've done my research about doing the swap/rebuild. I add up the total cost of parts and it comes out to roughly 20,000. But when I search JZ swap costs on the forums, people are posting some super low costs for the engine + parts needed (3,000-6,000). I remember when my stock sr swap/rebuild was about 7000. My list consists of everything for the jz to run like a new STOCK long block except fuel delivery upgrade and bigger turbo. I can't say I didn't expect these figures, but why is everyone else's investment so far from mine haha. *I swear against backyard/junkyard ideology builds. Something to discuss about?
I personally have never heard anyone quote $3k to $6k for a 1/2JZ swap... Maybe for an N/A, but certainly not turbo. What I normally hear is around $10k to $12k. I mean, a lot of money can be saved buying used or aggressively shopping for discounts/group buys. Never heard as high as $20k for any stock swap. That's nuts to me.
Probably the cheapest non-native engine I've heard of swapped into the S-Chassis is the VQ at around $7k if you used the FWD version. 1UZ maybe, but ugh. Why? lol
If I leave out the standalone, the turbo rebuild, twin disc + flywheel, wiring harness, custom exhaust + intake + hard pipes, gauges, oil cooler, converters for tach and speedo, tune. 12k is a possibility and a few other pluses. 12k is def a possibility.
![]() Join Date: Mar 2008
I'd just get the car running reliably then worry about the performance stuff later. Get the engine running on the stock ecu, stock oil cooler, bypass valve, etc. Then do the blingy shit later like the standalone, etc.
#8 | |
Turbo Rebuild? Step away from the keyboard and put your credit card away. You are. It ready. |
All true. But a 1jz swap has been on my mind for many years. I never really coped with the "just get it going first and then worry about the pluses later" idea very well. I am a pre-planner. I want to map out what I want and know the cost of it, and then dive into the project. Much love and respect for the rotary's and the 7's but not for me. I have a tuned Evo X as well, but I want to get rid of it for a daily driver...
![]() Join Date: Apr 2016
This. All of it. You can pre-plan all you want, but get it road worthy first. Enjoy it for a bit. Do it in steps. If you park it for a while, with little or no progress, you will lose interest. Seen way to many projects end up going to shit like that. Myself included. I planned out a project car back in 2004, went full tilt on it, then life happened. Got parked for a while, money and time got scarce, and it sat idle for years. I still haven't finished it yet.
#14 | |
Ever swapped an engine? |
#15 | |
2) Why are you purchasing custom exhaust and induction pipes? There are a multitude of brands which already make conforming parts which are MUCH cheaper than custom and just makes more sense 3) A stock setup does not need a "tune". Get it running first on the stock ECU 4) If you have the proper wiring harness, why are tach converters needed?? I would highly recommend you keep it as simple a stock swap as possible, which also tremendously reduces your cost of admission and downtime #/f/showthread.php?t=594842 Check that link out for all the detailed swap info. |
#16 | |
Like what are you even asking then. Of course your gonna dump 20k if you rebuild and replace everything. twin disc clutch, flywheel, custom this, that, rebuilt turbo. You said you've built an SR before, so why are you surprised? 1JZ with the essentials is going to be cheaper, duh. |
#17 |
d15, f22, 2uz, and an sr. Done a couple of other rebuilds, just not jz. I'm not surprised by the price. This was meant to be a discussion for others who've done the swap who can chime in. This also isn't my daily driver so I'm not concerned about getting it on the road ASAP.
#19 |
Someone said there are a lot of hard pipes and intake available for the swap but all I see is cx racing and I've never had good luck with fitment and quality from them. So custom it is.
#20 |
#24 |
Don't get offended, but a very similar post to yours pops up daily. If research was done, this post would not exist (and I provided a link to a full step by step swap and parts guide for you to come a much more precise figure in regards to cost).
And time and time again, it ether 1) Doesn't get off the ground 2) Goes about as far as a shell and the purchase of a ton a parts and the purchase of even more unnecessary parts, at which point reality sets in and a feverish partout ensues shortly after..........at which point everything is sold for cents on the dollar because OP and girlfriend broke up, they need a house and now everything needs to go........ Double - triple the price to build a 6 cylinder vs a 4 cylinder is a good baseline. Either way, good luck! Not my money or m problem lol |
#26 |
Like I said, this isnt my first project. I'm not some kid that's still in high school trying to ride the hype you know? I know the struggle of carrying motivation to finish builds. I've already been there years ago. I just wanted a discussion of a topic, I wasn't really ranting about the costs. I still plan to repaint the entire chassis, mild suspension and body work. My build goes beyond just the cost of this jz swap. I'm well aware of the expenses of doing a build. But when someone says that they'll wait until I fail and give up. Like what's the point of that...I already have more money saved up than I need to complete this swap.
#30 | |
Are you like 16? I don't think you've ever swapped anything. If you had, you'd understand how silly you sound. You are seriously rebuilding the POS C16 turbos? Why? They are garbage. You don't need a twin disk, ECU, FMIC, exhaust or anything to run those chokers. You are looking at all of this backwards. Also, fuck the 1JZ. Proper Build- Start with a USDM VVT-i 2JZ for $500 The VVT-i is worth 50hp once tuned. Now all your parts and specs will be easy to acquire. Have a custom turbo manifold built for $1,200-$1,500. Modify your stock intake, get some turbo valve covers. Now buy the Collins adapter and clutch setup. It's like $1,600 and comes with a clutch. Have a 1pc shaft made at your local. Now you can run a CD009 for $500. It's stronger, cheaper and better shifting then a R154 and a W58 is a pile of shit. If your gonna build, use Manley Pro H-beams. Best to use a cam driven mechanical fuel pump and FIC injectors. Run a MS3 Pro for a stand alone. Or AEM if your a dork. My friends 2JZ build is coming along nicely. Entire swap he'll be about $10k deep and making 1k WHP with billet main caps. He is doing all the fab work and assembly himself. If you are going to keep the stock turbos or run a W58, save your time and money. You'll struggle to get past 350whp. Just swap a RB25 or 5.3/LS1/ Ford 302. Jason made 390whp on his stock block RB25 before saying fuck it and going 2JZ. He had maybe $5k into that swap. But once again, he did all the wiring and fab and used a Z32 ECU. |
