need help with B&M short shifter install pics included
ok so i have pics now never done this install before
i dont know how to install the shifter. tried just bolting it in but once i had it in the shifter only moves forward and back and is pretty tight. so im know ive done something wrong my friend who was gunna do it for my said something about taking off the plate. so im guessing that he's referring to this blue b&m plate so this is where im at sorry for poor quality pics but theyll have to do also my clutch slave cylinder is not bolted up yet i cant seem to get the little nipple on it to go back in do i need to bleed the clutch?? and if soo how do should i go abouts doing that?? this the only thing keeping me from running my new s14 sr swap |
![]() Join Date: Dec 2002
So instead of installing the shifter, you took it apart?
Put the shifter back together. Make sure the transmission is in neutral and install the entire shifter assembly with the plate. There's no need for pictures because it's completely self explanatory.
no i did not take it apart my friend helping me with the full motor n trans swap did it because he said itd be easier to mount the trans with the shifter out
so now i am trying to re-insert the shifter w/o him but when i tried just bolting it in from these pics the shiter only moves back n forth as in only going into 3rd n 4th gear i have no idea if the trans is in gear or not |
![]() Join Date: Jul 2008
Take that plate off and reassemble it dawg. Then install the whole unit with the 6 bolts. The 2 front bolts are a bitch unless you have cool tools. I had to get under the car and undo the tranny cross member to get to them.
loosen off the crossmember bolts (4) 3/4" and this will drop the tranny by 3/4" and make it possible to get the front 2 screws in and tightened from below. Be sure to use jackstands for safety if you are under the car. Ratcheting wrenches made this job easier, but you could make it happen with regular ones. Use a gasket or RTV sealant before placing the plate on the tranny. Use some brake cleaner on a rag to clean the surfaces where the gasket material goes, and remove all of the old gasket before installing the new one.
You will be able to slip the shifter and plate into the hole in one piece at that point. Be sure the bottom of the shifter is seated in the hole in the tranny, or it wont work.
93 Hatch w SR20
![]() Join Date: Dec 2009
the springs go on top of the shifter. so install the shifter then drop in the springs on both sides. put the plate back on and tighten the allen head nuts back down. its going to be tough due to the pressure from the springs but with a little persistence you'll get it.
![]() Join Date: Feb 2012
Trader Rating: (37)
I bought a second hand B&M that was taken fully apart. I have all of the correct compents because I acquired them directly from B&M. I can't figure out the order that they are supposed to be assembled in.
I've searched, but nothing of help pops up.
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
