#3722 |
![]() Join Date: Nov 2005
Send them to www.fealsuspension.com
#3724 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
#3726 |
the RLCA is made for the OEM link, if you use aftermarket heim joint links then you need to weld a tab at a 90* angle to the exsisting mounting tab.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
#3727 | |
![]() Join Date: Sep 2009
Also my RLCA were a bear to get onto my subframe, the distance between the two contacts seemed too close by a few mm. |
#3728 |
![]() Join Date: Sep 2003
Fuck sway bars. I didnt even use one with my PBM stuff lol
My RLCA fit tight as well but really it was because some of my mounting tabs were a little crooked. Trust me it DOES fit. It may take some persuasion but once its in its solid and fits fine. also you could tap your mounting tabs out a little so they slide in easy then tap them back and the nut and bolt will bring it in tight. |
#3730 | ||
I ended up using a rubber mallet and went at it to get them in, there was no gap beween the bearing/bushing on the back subframe mount, but on the side that faces the front of the car there is a gap of a few mm so i put a small washer in. Quote:
Edit: posting that much from a fucking phone is a pain in the ass |
#3731 |
![]() Join Date: Apr 2005
I vote this thread be cleaned up and slimmed down to just the necessary comments and posts.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!! formerly sideviewcivic Save a Horse. Drift This Cowboy. AirBag Club Member #0014 |
#3733 |
has anyone ever shortened rear oem LCA's before? i know joel did this on his yellow car but i thought i remember him having some sort of issues.
i got an alignment yesterday and right now im at -6, id like to get it in the 3 or 4 range. the PBM joints look nice and i think it was stated they go shorter than stock? if it comes down to it i will just order those, but obviously making the oem shorter will be cheaper.
@pwrmves14 |
#3734 | |
![]() Join Date: Jan 2012
I'm full spl out back, so I can basically do anything. |
#3735 |
![]() Join Date: Nov 2009
I always like when I see new developments suspension and chassis wise for our cars
![]() Here's something new! www.TDP.ie » TDP Nissan S14/15 & R33/R34 Rear Camber Arms |
#3736 | |
![]() Join Date: Jan 2004
Trader Rating: (115)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 115 reviews
Those are epic but I don't see them as ground breaking.
This on the other hand.... Quote:
#3737 |
![]() Join Date: Feb 2009
Kits like that have been floating about the BMW community for years. BMW Motorsports even used a similar set up on some of the early DTM cars instead of making new hubs.
![]() Made from magnesium and the lugs were special and became the drive pins.
My Website | Unfriendly Garage | Endurance Motorsports | FitMyWheels - Fitment Calculator |
#3738 |
#3739 |
^THAT is awesome,....but probably way too damn much for anyone
cONtRol FReAkS |
#3744 |
#3746 |
I got this issue with geomaster 2 and lowercontrol arms from driftworks for my S14.
When i got the cone in the right place it seems that the bolt is to short or to long way up. i did have to make a spacer to get it to work cause otherwise the nut did catch the cone(DW recommend 2 washers but that wasnt enough) , now im struggeling with the cleerance of the wheel (rear)(original 16 and OZ 17"). And i cant fit the lower cotter pin front or rear.. What should i do ? any ideas ? ![]() ![]() ![]()
C=(-_-Q) |
#3748 |
Call Driftworks?
Looks like they now use a thinner coating on them... Driftworks GeoMaster - Race Hub Knuckles Driftworks Shop |
#3749 |
Take that top spacer out and you'll have room... IIRC that's for stock LCAs.
Hopefully with the new coating people won't have to file out the bolt holes and ball joint mounts. Looks like they finally include washers for proper fitment and instructions too. One thing they don't mention is you'll need the S13 rear strut to knuckle nut if being installed on s14. |
#3750 |
Have talked to driftworks, didnt get any good explanation..
Yes they have a new coating in the geomasters, my understanding was that they got alot of complains cause the paint didnt stick. This is why i need to the top spacer : ![]() And this is what i did : ![]() Now i could fit the lower cotter pin : ![]()
C=(-_-Q) |
| anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
