Old 02-11-2002, 01:24 PM   #1
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
I know at least 2 people have done this, and I wanted to know what parts you needed, where you got them from, how much, and how long.
Thx,
-Jeff
Jeff240sx is offline   Reply With Quote
Old 02-11-2002, 03:46 PM   #2
Ni5mo180SX
Ni5mo180SX is an unknown quantity at this point
Send a message via AIM to Ni5mo180SX
Ive done it
Ni5mo180SX is offline   Reply With Quote
Old 02-11-2002, 04:02 PM   #3
Grumpy
Grumpy is an unknown quantity at this point
What do you need to know.........................
Grumpy
Grumpy is offline   Reply With Quote
Old 02-11-2002, 04:05 PM   #4
anthony240
anthony240's Avatar
anthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really nice
Send a message via AIM to anthony240
<a href="http://240sx.cwilfert.com/performance_modifications/manual_conversion/manual_conversion_main.html
very" target="_blank">http://240sx.cwilfert.com/perform....
very</a> informative page!
anthony240 is offline   Reply With Quote
Old 02-11-2002, 04:38 PM   #5
Nismos14
Nismos14's Avatar
Nismos14 is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from Grumpy on 6<img src="#/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>2 pm on Feb. 11, 2002
Grumpy
</td></tr></table><span id='postcolor'>
he says what he needs to kno in his first post :cheesy:
Nismos14 is offline   Reply With Quote
Old 02-11-2002, 11:15 PM   #6
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
ok here goes. I have done it on a S13 and my friend did it on his S14.
so here goes
parts list
5 speed of course
5 speed drive shaft
5 speed cross member
clutch master
clutch slave'
clutch bleeder assembly
clutch lines
clutch pedal
manual flywheel
manual flywheel bolts
manual engine backing plate
clutch pressure plate bolts
pressure plate
driven disc
pilot bushing
shift boot
Now comes the fun part. on your inside firewall(drivers footwell area) you will find the outlines for your bolts and main hole for the pedal and clutch master. You need to drill these out. You can then hang your clutch pedal. the eaisest thing to do with the brake pedal is cut it with a dremel or die grinder. Its ten times quicker than dropping your steering column to hang a manaul brake pedal.
Ok now on the installation part. On S13's you can get away with running the auto ecu it will not throw a check engine code on S14's it does <img src="#/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=':('> Which pretty much facilitates putting in a manaul ecu. As far as the wiring goes there is a page on the web that shows you how to wire the auto trans harness to the 5 speed.
this is more critical on S14's due to OBDII than on S13's :briggrin: yes I am a S13 owner. On the S13 you can remove your auto harness all together and just wire in your back up lights from the connector for the auto harness by your firwall in your engine compartment(right hand side) . I have not found it necssary to hook up my 4th and 5 th gear sensors car runs fine with just the speed sensor hooked up and the backup light sensor hooked up. thats the general down low on most of the stuff . If you saw my car you would never guess it started life as an Auto tranny machine. If you really need to go the distance on the wiring I believe someone posted the site above for that.
Oh yeah if you need the swap parts I believe I have an extra set or two $250 there yours . Of course thats without trans or clutch those are up to you. I can get low mile manual trans but they are not cheap.
Old 02-12-2002, 08:28 AM   #7
Guest
Posts: n/a
seems like a bitch, good think i bought a manual in the first place
Old 02-12-2002, 11:14 AM   #8
drift freaq
not really, If you could not find a low mileage 5 speed and got a deal on an Auto , you would see why I did it. My car has 23,000 documented miles on it:biggrin: and its a 91 fastback!.
Of course yes If you can find a 5 speed its the best way to go. But if you have money in your car already that you won't get out of it or your attached to it. Its not that much of a hassle its actually like a half to one day job. the trick to it is getting all your parts together first. If you do that it comes together quite fast.
I have several friends here in So Cal that did the auto to SR20DET 5 speed swap all at the same time. The truth is you can pick up Auto's here are in much better condition than the 5 speeds . everyone driving 5 speeds here in socal tends to drive them hard and put lots of mileage on them. Now I am not saying everyone go out and look for a 5 speed . If you can't find one though its not the end of the world and in So Cal #### all over Cal sometimes finding a good 5 speed is a beeatch.
