Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales
Advertiser Specials and Sales Dedicated for Zilvia Advertiser Sales and Specials
Old 08-19-2008, 04:50 PM   #1
[email protected]
kuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond repute
SPL PRO outer tie rod ends NEW VERSION 5
SPL announces yet another update to our PRO outer tie rod ends. Our new version 5 shanks are now made from 9310 steel alloy (Nickel-chromium-molybdenum steel), this super tough alloy is what is used in performance transmission gears! As some of you know we were backordered on the tie rod ends for the last 3 months, the main reason was that we had to wait 2 months for the material (very hard to find in such a small diameter).
9310 has greater impact and tensile strength over 4130 chromoly, we selected this material to withstand the impacts from the steering assembly bouncing off the steering stop when drifting. Our v5 shanks are heat treated to 190ksi tensile strength (similar to ARP head studs!), and are about 25% stronger than our v4 shanks:
certification
Our v4 tie rod ends were the strongest on the market, and our v5 end take it to the next level! We guarantee this IS the strongest product on the market by far. Our design and strong (and expensive) materials set us apart, that is why our outer tie rod ends have stood up to the abuse and others haven't.
Most other features remain unchanged from v4, including:
QA1 high misalignment rod ends, with a crazy 65deg misalignment angle to prevent the tie rod end from binding up on slammed cars. Other tie rod ends allow for only 20-35deg misalignment. We also use 5/8" rod ends, which are much larger and stronger than those used in competing products.
Up to 1" bump steer adjustment (more than anyone else), with our Super Duralumin (2024 aluminum alloy) adjustment spacers
Super Duralumin (2024) buckle for lighter weight -- unlike many of our competitors, we do not use regular 6061 grade aluminum which will strip out in this high stress application. 2024 aluminum is 50% stronger than 6061, there is a difference!
Ability to use Z33 (350Z/G35) or Z32 (300ZX) inner tie rods -- strong, cheap, easy to source
Chris Forsberg uses our v4 (not even v5!) outer tie rod ends (as well as our other suspension links) on his Formula-Drift 350Z this season! Chris Forsberg Racing :: Home
Our v5 outer tie rod ends are $229 and are finally in-stock and shipping!
Owners of our v1-v4 outer tie rod ends can order upgrades to the latest version from this page:
http://www.splparts.com/main4/parts/...e%20rod%20ends
kuah@splparts.com is offline
Old 08-19-2008, 04:55 PM   #2
OptionZero
OptionZero's Avatar
OptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfectionOptionZero is close to perfection
Send a message via AIM to OptionZero
damn you kuah
posting these while i'm waiting for the S14 RUCAs
lol
OptionZero is offline
Old 08-19-2008, 05:02 PM   #3
A Spec Products
A Spec Products's Avatar
A Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfectionA Spec Products is close to perfection
Send a message via AIM to A Spec Products
Super duper legit
SPL Parts been in the game longer than you owned your 240
And they have actually put in DEVELOPMENT and TESTING into their products to make them better and better
LOOK AT THAT SHIZ
They have a CERTIFICATION showing the heat treating, nice!
Keep up the good work Kuah!
A SPEC PRODUCTS CORP
AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more!
626.618.1100 x 103 / aim: aspectuan
Advertiser's Specials! Read / Give Feedback! Please Rate Us!
A Spec Products is offline
Old 08-19-2008, 05:40 PM   #4
[email protected]
Originally Posted by OptionZero View Post
damn you kuah
Well at least I didn't post about the RUCAS
Old 08-19-2008, 05:40 PM   #5
[email protected]
Thanks Logan! BTW I am sending you a PM for another Works Bell hub
Old 08-19-2008, 05:43 PM   #6
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
oh my..those are nice. a little salty on the price but damn, you cannot say that isnt worth it! id rock them over kazama anyday
ch1873857 is offline
Old 08-19-2008, 08:27 PM   #7
dannyk20
dannyk20 is an unknown quantity at this point
this a must have..........will this v5 outter tie rods end bolt up to the TEIN inner tie rods
of a S13?
dannyk20 is offline
Old 08-20-2008, 06:57 AM   #8
[email protected]
of a S13?
Unless you have certain modded spindles (MA Motorsports, etc), our outer tie rod ends will not bolt up with the standard Tein S13/S14 inner tie rods. Our outer tie rod ends are designed to be used with either OEM Z32 or Tein Z33 (350Z) inner tie rods...
Old 08-20-2008, 08:41 AM   #9
dannyk20
which one do u have to bolt up with the Tein S13/S14?
dannyk20 is offline
Old 08-20-2008, 10:21 AM   #10
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Just upgrade to the Z32 Tein ones, their older stuff isn't as awesome as their newer stuff. You can always sell your old Tein ones to someone else just getting into the game.
Plus when you upgrade you get the convenience of being (for the most part) up to date with their current catalog.
I'm rocking the V4s on my car.
FaLKoN240 is offline
Old 08-20-2008, 10:58 AM   #11
[email protected]
We can custom build one to fit the Tein S13/S14 but the buckle will be steel instead of Super Duralumin. Also you may have to cut a little off the length of your Tein inners to get the toe in spec, this is a common issue with getting aftermarket outers to fit with the S14 style inners. That is why we no normally do not sell this setup anymore.
Old 08-21-2008, 12:29 AM   #12
dannyk20
whats the different between Tein S14 and Z32 inner tie rod. they look very simular?
dannyk20 is offline
Old 08-21-2008, 12:38 AM   #13
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
I have some older spl ends but im missing the bump steer bolt and spacers, is there anyway i can purchase them from you?
projekt_s13 is offline
Old 08-21-2008, 12:54 AM   #14
94cc0rd
94cc0rd's Avatar
94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute94cc0rd has a reputation beyond repute
Send a message via AIM to 94cc0rd
I'm definately going to pick these up soon.. I hear nothing but good things about SPLparts.
So for my s14, since I drift, I would need Tein z33 inner tie rods and these v5 outer tie rod ends right? They would bolt right on?
94cc0rd is offline
Old 08-21-2008, 10:20 AM   #15
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Well besides the obvious threading is different, probably the lengths and of course the ability to use the new SPL stuff
Haha, I honestly don't know, you should be asking Kuah.
Old 08-21-2008, 10:35 AM   #16
oneviaman
oneviaman's Avatar
oneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond repute
same thread same o.d. z33 is like almost 2in shorter than s14.
oneviaman is offline
Old 08-22-2008, 06:32 AM   #17
[email protected]
Right, the Tein Z33 inners an SPL v5 outers would bolt-on when installed together.
Old 08-22-2008, 06:35 AM   #18
[email protected]
Yup, and the Z33 inners are actually beefier as well. Our outers are therfore longer than the stock/Tein S14 outers...
Old 08-22-2008, 12:28 PM   #19
FerretsCanDrift
FerretsCanDrift's Avatar
FerretsCanDrift will become famous soon enoughFerretsCanDrift will become famous soon enoughFerretsCanDrift will become famous soon enoughFerretsCanDrift will become famous soon enough
Just when u thought SPL couldn't get better
FerretsCanDrift is offline
Old 03-05-2009, 04:50 PM   #20
99maxgtr
99maxgtr's Avatar
99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices99maxgtr has made poor choices
so is there any special zilvia.net pricing or discount on these
You're 16. You barely know what kind of girls you like.
99maxgtr is offline
Old 03-05-2009, 06:12 PM   #21
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
This is a dumb reason to bring back a thread.
Old 04-06-2009, 10:24 PM   #22
dillyumpshous
dillyumpshous is a well-known jackass
kuah please tell me you have them in stock... pm sent
dillyumpshous is offline
Old 04-06-2009, 10:29 PM   #23
adrians_s13
adrians_s13's Avatar
damn dude... SPL is like the ipod of suspensions... by the time you install your SPL arms, a new version gets released!
@adrianfromthecastle
adrians_s13 is offline
Old 04-07-2009, 06:33 AM   #24
[email protected]
Sorry I just ran out on the first batch, the next batch of 9310 alloy shanks are getting machined right now eta is 2-3 weeks for machining, heat treating and plating.
Old 04-07-2009, 01:48 PM   #25
dillyumpshous
does it work with ikeya inner tie rod?
Old 04-07-2009, 01:57 PM   #26
[email protected]
It will work with the Ikeya inners if you have modified knuckles (ie. MA Motorsports, PBM, etc).
Old 04-08-2009, 10:55 AM   #27
PoorMans180SX
PoorMans180SX's Avatar
Is there any way I can get shorter shanks? I don't need the bump-steer adjustment because I'll be using PSM knuckles.
I had v4's on my other car, and they were great! Steering feel was much better.
PoorMans180SX is offline
Old 04-08-2009, 11:00 AM   #28
[email protected]
You can just cut off the extra length of shank if it is not needed
Old 04-09-2009, 09:34 AM   #29
PoorMans180SX
There are still enough threads? Coool.
I'll use the spacers for now, and then when I get the knuckles I'll cut the extra shank off.
Good deal. Expect an order soon!
Old 04-09-2009, 09:46 AM   #30
[email protected]
Basically you install it with the configuration of spacers you want, leave any unused spacers off, any part of the shank that sticks out past the bottom nut can be trimmed/cut off as needed.
