#32 |
Thanks people! Can't tell by the video but I was freaking out.
Currently waiting on a left brake rotor and will be finishing the brake lines as soon as I can. I've been aiming to have the car mobile by Sept 1st ever since I broke my arm. It looks like it's gonna be really close! On another note, I've been comparing the fuel level sensor resistance between the cars. The S runs ~80 ohms at empty and the Z runs 123 ohms at empty. A big issue with just swapping the sensor, aside from fit, is that the Z has TWO fuel level sensors in series that make up the 123 ohms... one on each side of the tank. They did this due to the fact that the tank straddles the driveshaft. Fair enough, but the issue is that by running JUST the single S sensor, the Z gauge will show the tank as full CORRECTLY, but the tank should run dry somewhere around the 1/3 mark. Shit. So I'll see about wiring in the secondary Z sensor (luckily it's range is ~40ohms) to the S fuel level resistor in-tank. I haven't put in the new fuel pump so I haven't taken a good look at it yet, but I'll make sure to post what I find. I've got a similar setup with the front ABS sensors. I've got to get a set of S ABS rings and possibly sensors too, but it looks like I'll be building a board to mediate signal between what the Z is sending and expecting back in terms of pulses, and the S setup. The S has a tone ring with a sensor running an electromagnetic mechanism. The Z seems to run the opposite by having a segmented magnetic ring on the inside face of the front hubs actuating an iron filament completing the circuit to indicate rotation. It may just be as simple as taking a count of the Z tone ring "teeth", tooth count of the S ring, and making a signal modifier to translate the appropriate signal. Apparently I'm a glutton for punishment because these kind of issues seem to be what I get into the most. What a loser. Last edited by Jissan; 08-27-2013 at 01:07 AM.. |
#35 | |
![]() I know driver assists like traction control and ABS get a bad rap but I would like the option to run the assist or disable it if I choose. Say I bite the bullet and get some Hoosiers for a series but I'm unfamiliar with the track layout (with autocross that's always). If I make three runs and push a little too hard on the fourth and slam the brakes in a moment of panic / n00bness to avoid a person / cone / wall, I've just flatspotted my tires and will have to shave them to even them out, or worse: have to throw them away... It's definitely a good thing to have the option to run ABS and be able to choose not to. |
#37 |
DriveshaftShop delivered.
![]() Got some open box Kinetix HR cats in from Enjuku. I asked for an Enjuku sticker. They sent a stickerbomb starter kit. Wrapped the cats with DEI Titanium and coated with VHT Flameproof. ![]() ![]() ![]() Also finished up the brake lines: Lines run to the manifold, additional line run to the rear. Rear T deleted and each side has it's own line now. ![]() I ran into a huge drama when I went to bleed the clutch. Firstly, the HR motors have an internal clutch slave cylinder and a tube that goes into the trans for fluid and bleeding. Well, the bleeder valve head broke off in the CSC tube block. Then the EZ-Out broke off in the bleeder. Fast-forward through an insane amount of profanity at high volume and I'm back in the garage with a replacement CSC tube. Little did I know they are typically replaced with the trans off the block. The hole for the CSC tube is about the same size as a clutch fork hole and we could barely even see WTF was in there. Eventually we were able to pull the pin holding the old CSC tube with a pair of 10" hemastats holding a locking pin clip and a dentist mirror. We put the pin back in with the hemastats, popped the new CSC tube in, and proceeded to bleed the clutch. Let it be known for anyone bleeding a VQ trans with a dry CSC, proceed like this:
You see where this is going. The key is the waiting. Trust me, I burned almost two hours cursing and trying different crap. Just so you know, vacuum bleeding did NOTHING for me besides gum up my vac gun with Wilwood 570. I'm going through the drivetrain and suspension looking for loose bolts and putting in thermal protection on the passenger side frame rail due to the fuel and brake lines running close to the heat. After that I'll loosen the motor mounts and clock the motor about 2 degrees counterclockwise from driver's orientation ( the motor is ever-so-slightly crooked ), tighten them back up, throw the manifolds, cats, Y-Pipe, rear exhaust, fab a middle section from the Y-pipe to the S13 exhaust, throw a seat in that B, go around the block, and immediately put it back in the garage cuz there's still no interior at all. |
#38 |
![]() Join Date: Mar 2009
Looks great so far. Good work.
Do you need; Right side (USDM Passenger side) Replica S13 OEM Silvia Aero Bumper Grill S13 Silvia J's, Q's, K's, A's Bumper grill inserts. Male Plugs for S15 headlights PM me if you need them. |
#41 |
![]() Join Date: Oct 2006
A man after my own heart! You really did it right by getting a totaled shell to start off with, that's my plan as well.
Can't wait to see a finished product! |
#42 | |
I guess I'm going for a sleeper attitude. I've been talking to a lot of Z owners and they've said test pipes are obnoxiously loud, but I'm taking their advice. Thankfully the cats were super cheap, and Kinetix has a good reputation. |
#45 | |
Since I bought my car on Copart, I had to bid against other interested parties. Settle on a value that you're happy paying and if bidding goes over that, it'll make you reconsider the overall value you'll pay or you'll learn from it and refine what you're looking for in a donor. |
#46 |
Funny you mention Copart, I've always looked at cars on there, and that's where I've been looking for a Z33 at since I decided to do this swap. But none of the local Copart yards have a Z I could get for a good price. Closest one is Tennessee
#48 |
I had kept my eye on a few Z's in some close yards, but the NISMO popped up literally 30 minutes from my house. I was able to go check it out, start the motor, and look at the block and tranny. I was bidding against someone in Florida, who undoubtedly hadn't seen the car, and won, probably because I knew it was safe to go higher.
#52 |
Well I'm going to need to reroute the fuel lines, rework the cats, or both. Cluster is throwing a fuel temp sensor CEL since the passenger cat is apparently boiling the fuel. Also it's melting the carpet to the sound deadening.
*sigh* But it's getting there. It's a blast to drive. |
#54 |
![]() Join Date: Jan 2011
yup depending on the type of driving and time inbetween stops the exhaust can get hot...I've since re wrapped and double wrapped my LTH while coating the bottom of car and tunnel area with high temp paint...
hope that helps |
#55 | |
![]() Join Date: Feb 2006
#56 | |||
Lots more work ahead people!
![]() Quote:
Alignment scheduled today, mainly to get my toe corrected, as well as check on the rest of it. Front is toed in badly since I changed steering racks and rod ends. It was so bad that my front NT05s were chirping going over expansion joints on the interstate. I only went about 3 miles and got home and did a rough correction with my limited tools but a lot of damage had already been done to the tires. Oh well, they're almost a year old and that's plenty of use out of a set of 200 treadwear tires. ![]() |
#57 | |
![]() Join Date: Feb 2012
#59 |
Alignment was eye-opening.
LCAs front and rear had bad bushings. Steering rod ends had binding angle at what is definitely a conservative ride height. RUCAs had fused jam nuts so they couldn't adjust them. Wheel/tire combo had minimal coilover clearance for camber adjustment, so camber plates are needed. Shit! LOL! |
#60 | |
Stack 8130 Tachometer with VQ35
I would be grateful if you could tell me how you got your Stack tach to function. Thanks for any info! Tom |
| nismo 350z, s13, vq35hr |
