![]() Join Date: Jul 2012
timing advanced out of no where
So i installed a different turbo on my stock sr two days ago and got it running and what not.
Hooked my computer up to the consult plug and used nissan data scan to see what it was doing. Everything seemed fine, besides a knock sensor code. Timing at idle was at 15btdc Two days later though and now I'm idling at 20btdc. Anybody have any advice as to what my problem may be? I would search more, but i don't know exactly what questions i need to be searching for |
![]() Join Date: Oct 2005
Use an actual timing gun to check. Otherwise I'd check if somehow the CAS became loose.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd |
Well i just went back out and hooked the computer up again and now its idling at 15 again. Hmm
Im still gonna hook my timing light up and see if it's indeed at 15btdc |
Check your TPS voltage. Should be less that 0.48V with throttle closed. The ECU uses a different timing table when the throttle is closed.
NismotronicSA - Speed-Density Tuning for Nissans |
