Old 06-16-2010, 08:29 PM   #1
oung
oung is an unknown quantity at this point
dropped bolt into head...please help!
hey guys so today i took off my valve cover and found out today that the bracket that goes over the timing chain broke off...i took it off and i also started to unbolt the two bolts that hold it on, well upon doing so, one of the bolts fell from my hand and fell into the gap opening in the timing chain area.....i took out my distributor and it fell even deeper...i tried getting it with a magnet after that and could not get to it....im just wondering if anyone knows where it exactly fell to after i removed my distributor?? and can anyone tell me how i can get to it? i really need help...please....
oung is offline   Reply With Quote
Old 06-16-2010, 08:42 PM   #2
Om1kron
Om1kron's Avatar
Put your car on jackstands and remove your oil pan buddy.
When that shit breaks regardless this is where it ends up.
Wayne
Old 06-20-2010, 06:55 PM   #3
oung
hey update.....bolt that i dropped was not in the oil pan.....any more ideas? plannin to pull the motor
Old 06-20-2010, 07:08 PM   #4
Sileighty_85
Sileighty_85's Avatar
flash light and stick magnet?
They make a stick magnet with a flash light built into it too
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-20-2010, 09:59 PM   #5
j20accord00
j20accord00's Avatar
j20accord00 is an unknown quantity at this point
Send a message via AIM to j20accord00
i had good luck rotating the motor by hand slowly. sometimes it doesnt make it to the pan and if you move the motor it may drop to the pan
92 Coupe ka-t
j20accord00 is offline   Reply With Quote
Old 06-21-2010, 01:45 PM   #6
stinky_180
stinky_180's Avatar
Trader Rating: (26)
stinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud of
Feedback Score: 26 reviews
Send a message via AIM to stinky_180
Remove the front timing cover
SoCal RallyX Coverage and MTB Ride Reports
WheelsDirty
stinky_180 is offline   Reply With Quote
Old 06-24-2010, 06:05 AM   #7
jdmisaac
jdmisaac is an unknown quantity at this point
dang that sucks man
shits aggravating.
but yes front timing cover i would say,.
jdmisaac is offline   Reply With Quote
Old 06-24-2010, 04:05 PM   #8
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Either that, or it's laying ontop of the main bearing girdle on the bottom, or potetially stuck in the timing chain guides....
I know it's a PITA, but removing the front cover is a serious job for someone without some moderate skill (not assuming you don't have any, but saying in general). Removing it on a car with a stock headgasket will undoubtedly ruin the front seal, causing leaks regardless of how much silicone you dab in there (as when you push it back in, it'll knock the sealant out. It will also require you to remove the lower pan, and the upper pan (along with cross member.
To me, I'd simply take the lower pan off, remove the cross member (put a jackstand under the front of th transmission, leave the rear tranny cross member in place), and remove both pans. From there you should be able to see it, and or use a magnet to get at it. I'd do anythign in my power to not remove the pump or the head if a stock headgasket/stockish power level car.
Old 06-26-2010, 12:00 AM   #9
killbillsnj
killbillsnj is an unknown quantity at this point
Send a message via AIM to killbillsnj
remove front cover i agree with that
killbillsnj is offline   Reply With Quote
