![]() Join Date: Apr 2012
Not 100% sure but that cable might be a ground for something? i have an s13 so i wouldnt know, just a thought. And try adjusting your handbrake from the nut on the hand brake leaver if that doesnt work try adjusting the ebrake assembly in side the drum, there a hole on it to do so.
That cable is probably for your blend door and/or vents. Typically coolant inside is a dead give a way that your heater core is leaking.
My SR20VET |
