![]() Join Date: Aug 2017
Impossible to find bolt size thread
Does anyone know the size of the rocker arm bolts and the bolts for the camshaft hold down? My bolts seemed to have grown legs and walked away. I’ve searched all over, high and low and cannot find a thing. Searched numerous forums, searched all over google and nothing. Only thing I was able to find is a Nissan part number for the replacement rocker arm bolts (1305840F10)
#2 | |
This is on a KA btw, forgot that piece of important info lol Sent from my iPhone using Tapatalk |
TYPICALLY, if a 10MM socket removes it, its a M6 bolt. Nissan religiously uses a 1.0 pitch.
I would compare it to what foreverdeath said, seems like it would be the right length. M6 x 1.0 x 30MM
![]() Join Date: Jan 2010
find some spare bolts you have laying around and try to thread them in. once you find the right one, measure it with a thread gauge to get the pitch. you can then run it though a die to see the shank dia (or take it to the hardware store with you and run it through their sizing guides).
as for the shank length, take your cap, put it on the cam, use the tail/end of a micrometer and determine the overall length. if its, say, 30mm, use a 25mm shank bolt. if you dont have these tools. buy them. in the meantime, take your head to a local hardware store and try to thread some bolts in. most places are pretty cool about it if you arent dicking up their hardware. |
