Old 03-18-2011, 10:12 PM   #1
Nicelyphe
Nicelyphe's Avatar
Nicelyphe is an unknown quantity at this point
When i turn on my electric fan.
Well I have an electric fan on my mishimoto radiator, connected to a rocker switch in the cab. Motor idles fine and such, except when I flip the switch on. Once i switch it on i get unusual motor noise and the idle drops a few hundred rpms. About 200-300 from where it normally sits.
Nicelyphe is offline   Reply With Quote
Old 03-18-2011, 10:17 PM   #2
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
ur drawing too much current...did you use any relays?
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 03-18-2011, 10:24 PM   #3
Nicelyphe
Nicelyphe's Avatar
No, its straight battery to switch to fan,
Old 03-18-2011, 10:30 PM   #4
josephin510
josephin510's Avatar
josephin510 is an unknown quantity at this point
The fan might be drawing to much amps. Check voltage before and after you hit the fans.
Trade my Rb25 for some wheels.
Buy my Sc300.
josephin510 is offline   Reply With Quote
Old 03-18-2011, 10:32 PM   #5
Nicelyphe
Nicelyphe's Avatar
There a way to stop that? Im not electricity experienced, and especially not with relays.
Old 03-18-2011, 11:00 PM   #6
90hatchie
Banned from the Marketplace
lose the shitty e-fans and go back to the reliable simple clutch fan and shroud
Old 03-19-2011, 12:20 AM   #7
Banana_Cute
Banana_Cute's Avatar
Banana_Cute is an unknown quantity at this point
that, I did the E-fan crap. dual too. and then at times my car would run hotter than normal..and also depending on your amp on the switch, it can blow and you can be runnin your car w/o a fan at all.
Been there done that, so i jst went back to the OE set-up with the A/C fan and clutch fan with shroud. worries went away.
Simplicity is the key to brilliance
Banana_Cute is offline   Reply With Quote
Old 03-19-2011, 06:16 AM   #8
Nicelyphe
Nicelyphe's Avatar
E fan was a quick set up since the clutch fan that came with my sr was beat. Anyone know how i can fix this power issue?
Old 03-19-2011, 07:22 AM   #9
lazysk8er2
lazysk8er2's Avatar
hellooooooooooooooooo wire it correctly you answered your own question
Old 03-19-2011, 07:42 AM   #10
Nicelyphe
Nicelyphe's Avatar
I got it all wired up, looking at
Battery to switch
Fan to switch
Fan to ground
Switch to ground
All works, just get the rpm surge when i turn it on, and engine noise as well.
Old 03-19-2011, 08:46 AM   #11
Nicelyphe
Nicelyphe's Avatar
Im starting to think possible alternator going bad? Also get a little rpm drop when i turn on my headlights, dash lights also dim and come back when i turn on the headlights.
Old 03-19-2011, 10:39 AM   #12
lazysk8er2
lazysk8er2's Avatar
you need some sort of relay to regulate the power cuz ur running the fan at max capacity...you can burn out your fan and blow out your alternator
Old 03-19-2011, 01:46 PM   #13
Nicelyphe
Nicelyphe's Avatar
Ah i see, someone told me it could be grounds since it also does it a little when my headlights are on as well.
Old 03-19-2011, 03:08 PM   #14
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
Fans draw alot of current, so youll need a 30 amp fuse to a relay to the fan then to a switch to ground
jacobs13 is offline   Reply With Quote
Old 03-19-2011, 03:13 PM   #15
Nicelyphe
Nicelyphe's Avatar
Ah i see, any certain kind of relay?
Old 03-19-2011, 08:37 PM   #16
lazysk8er2
lazysk8er2's Avatar
search there are a ton of diagrams available for efan installs
Old 04-15-2011, 08:16 AM   #17
surfpac
surfpac's Avatar
surfpac is an unknown quantity at this point
Your lights dim and idle drop because on initial fan start up the fan/s draw high amps due to a transient response. The amperage settles back down, but it is still drawing amps and make your alternator work harder hence the effect on your idle. even if you had this wired to a relay, the fans will still draw the same amperage. Ok, couple questions:
1. What type of fan/s are you using?
2. Still using stock alternator? (I recommend Quest 125 Amp upgrade if you insist on electric fans, HID's, etc)
I use Audi dual fans with digital 2 speed fan controller and Audi fan resistor. Also 125A Quest alternator. No issues at all.
surfpac is offline   Reply With Quote
Old 04-15-2011, 08:23 AM   #18
surfpac
surfpac's Avatar
Even with a relay the fans will still draw a lot of current.
Old 04-15-2011, 08:45 AM   #19
kanekoa28
kanekoa28's Avatar
kanekoa28 is an unknown quantity at this point
#/f/tech-talk/173441...fo-inside.html
heres a good thread to start off with got couple diagrams in there 2
kanekoa28 is offline   Reply With Quote
Old 04-15-2011, 10:09 AM   #20
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
There are a few things to address:
1. You should really get a relay in the setup to turn the fans on. Sure the amp draw will still be there, but it will keep things from melting down/failing.
2. The RPM drop is normal with more load on the system. The only true fix is to put a bigger alternator on it (I sell Quest Alternator conversion kits)
Don't read to much into the hype of a stock fan being the cats-ass, they are loud, a PITA to work around, and generally the fluid couplings in them suck anyway. A properly shrouded and setup E fan will work equally good as the stock fan at all times.
(PS: When are you bringing your car up?)
Old 04-15-2011, 10:44 AM   #21
Walperstyle
Walperstyle's Avatar
Ignore this guy. ^
You could try installing a better alternator.
KA-T ORG-Function over Flush
Old 04-16-2011, 11:12 PM   #22
Nicelyphe
Nicelyphe's Avatar
Yea, I think im def going to be looking into the upgrade kit through Cody.
