Can't rev pasted 3500rpm help!
So over the last couple of days I've installed a new exhaust manifold on my t28bb with full exhaust system with a deleted cat and it was all made by the same company "TOG auto". So I start it up and it sounds pretty weird but I figured that's just the new exhaust. Then I take it around the block and it won't rev 3500rpm. If I try it runs ruff as guts and kinda feels like the turbo it self is stopping it self. I put everything back together the same way I took it apart, all the bolts are tight as f**k plus locking tabs on the turbo, air flow meter is hooked up, a wire broke on the o2 sensor so I solded a bit of wire in there and I plugged up the egr pipe that went to the stock manifold. I'm really lost, pissed off and I need help. My suggestion so far has been boost leak but I've checked all my lines to my boost controller, my ecu which is stock, a boost cut which I was only running 10psi before I swap everything out an it ran fine and someone thought that since I solded a wire to link two broken ones together on o2 sensor.
So lost >_< I've asked TOG over facebook but it's late, I've got a few responses of them but they'll call me tomorrow or on monday.
