Old 12-24-2007, 12:02 PM   #1
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
s14 w/ ABS brake bleeding order *searched*
I've searched and cannot find a definitive answer on the brake bleeding order and procedure for the s14 w/ ABS.
I've found that people have mentioned to start with:
#1
Passenger Rear
Driver Rear
Passenger Front
Driver Front
Than I found:
#2
Driver Rear
Passenger Rear
Driver Front
Passenger Front
#3
Than I found that people bleed 2 star screws on the ABS module.
Which do I use to bleed my S14 w/ ABS?
#1? #2? #1&#3? #2&#3?
Thanks guys I just want some sanity
Maybe Russ could chime in?
parking lot pimpin...
Seller Feedback here:
#/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 12-24-2007, 12:17 PM   #2
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
ABS brake bleeding on ABS cars are the same as any other car. RR,LR,RF,LF. The only reason people say you may need to bled the pump is not all ABS pump are designed the same. When you bleed the brakes with the car off, the pump isnt on.
The best way to do it is to bleed it once and then go out and make some sudden hard stops to initiate the ABS. This gets the fluid worked through the pump. After that, go bleed it again. This will get all the dirty fluid out.
I have an ABS car and have always done it like any other brake system. Never had a problem with it.
garagelu is offline   Reply With Quote
Old 12-24-2007, 12:24 PM   #3
jspaeth
jspaeth's Avatar
jspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfection
Yeah....I have a question too about the ABS....I know you can bleed the ABS using the 2 TORX screws on top of the unit, but where does the fluid come out?
I didn't see a bleed nut or somewhere to put a hose on....does the fluid just pour out the top hahah?
Daily driven
jspaeth is offline   Reply With Quote
Old 12-24-2007, 01:09 PM   #4
S14DB
AFC #1
S14DB's Avatar
It's Right Rear, Left Rear, Right Front, Left Front for all 240's. ABS you just pull the connectors on the ABS module to make sure the solenoid's release(or pull the batt ground).
Old 12-24-2007, 01:14 PM   #5
hustlervibes
Banned from the Marketplace
hustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfectionhustlervibes is close to perfection
Send a message via AIM to hustlervibes
I always learned that you start farthest away from your BMC and that would be passenger rear.
hustlervibes is offline   Reply With Quote
Old 12-24-2007, 01:20 PM   #6
jspaeth
jspaeth's Avatar
Yah it's different for ABS because of how the hardlines run, the lengths are different than they would be with no ABS
Daily driven
Old 12-24-2007, 01:24 PM   #7
S14DB
AFC #1
S14DB's Avatar
No, It's not. Get an FSM. I have one on the shelf next to me. Only thing you have to do is disable the abs module.
Old 12-24-2007, 02:32 PM   #8
projectRDM
projectRDM's Avatar
Bingo. Unplug the actuator and bleed as normal. I've never had to bleed the actuator itself.
FORMERLY R240NA
Old 12-25-2007, 03:19 PM   #9
timlush
timlush's Avatar
timlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to behold
Send a message via AIM to timlush
Actually, on S-chassis, the left rear is farther from the MC than the right rear because of the way the lines are run. (USDM)
timlush is offline   Reply With Quote
Old 12-25-2007, 03:48 PM   #10
sillydrift
sillydrift's Avatar
sillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond reputesillydrift has a reputation beyond repute
Send a message via AIM to sillydrift
this is the bleeding sequence out of the nissan service book for the 240sx
just like mentioned above disable the abs module
sillydrift is offline   Reply With Quote
