![]() Join Date: Apr 2012
ISIS Radiator vs.....
I'm in the need for a new radiator and was wondering if anyone has had any issues with the isis radiators and/or hoses?
*ISIS Radiator Cooling Package - Nissan 240sx KA24DE 95-98 - Enjuku Racing Parts, LLC Or any recommendations would be greatly appreciated I'm also going with efans |
![]() Join Date: May 2011
The video at the bottom of the Enjuku page is of me installing the radiator and fans into my '95. I've had no problems with the radiator or fans since installing them last year. I will be picking up a set of the ISIS hoses in the next couple of weeks also. My old hoses finally have met their time.
http://www.youtube.com/canaanmanley |
The previous owner of my car had one electric fan and he ran the trigger off the wiper motor harness. It has a wire that has power turned on with the ignition. The constant power is inside the distribution box in the engine bay. That is running one of the fans. I haven't wired the second fan yet, but it will be triggered off a switch from the inside center console so I can control it when I would need it on only.
![]() Join Date: Dec 2010
Trader Rating: (42)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 42 reviews
Run one then the other, tell me which one runs cooler
This topic has been covered. Close this thread and google it before somebody comes in here and rips you a virtual new one |
#11 | |
So don't be trolling ![]() And if people in Arizona and Florida, where I live, run efans with no issues then I'm going to try it. |
Trader Rating: (42)
Why? What benifit are you getting? Or is it just cause everybody else does so your going to? Now your going to have wires, fuses, and relays running around waiting to fail you when you can just have your shroud and clutch fan and don't bave to worry about stuff failing
#14 | ||
What does age have to do with anything? My speciality is computer based, not car based, that is why forums are made for, to ask questions or am I mistaken? |
Trader Rating: (42)
Ls1.... Now it makes sense. Im forced to do the same. But for now you have a ka. No point in the fan. Just leave it stock. Save money. I'm undergoing my ls swap. Have your number you think your going to spend. And times it by two and some. Then the swap will get done
Good luck. |
#16 | |
Enjuku will be doing my ls1 swap...but I need these minor issues fixed so I can at least drive my s14 |
#17 | |
It is!!
With a properly bled and maintained cooling system, either with e-fans or the clutch fan the temps will be in roughly the same area. Depending on weather conditions and how you drive. Quote:
You didn't own anyone you twirp! Try and stay on topic next time you want to troll kid. |
#18 | |
#19 | |
#20 |
Seems like this would be perfect to control the fans
Buy Imperial Adjustable Thermostatic Fan Control 226204 at Advance Auto Parts |
#21 | ||
I still need to invest in a thermostat controller for my dual e fan setup. When I bought my s14 it had one single e fan on it, but a year later it burnt up after being wired to come on with the car and only go off when the car was turned off. I still have my new fans wired that way but I plan to change that soon. |
#22 | |
#23 | |
![]() Join Date: Jan 2008
#24 | |
I used to run the clutch, yes it is the optimum cooling set-up. But i own a boosted KA, i'm always fucking with shit. The clutch fan and shroud are a pain in the ass when doing many things on your car. Relays failing? All my relays are still oem and they outlasted the clutch fan? Ever drop a VC bolt or similar while having a clutch fan? Maybe if you're a 7 year old starving child from Sudan reaching down past the clutch is cake, but if not, that bitch is annoying as fuck. I have e-fans now and the headache they prevent is much greater than the initial headache they can produce to install (which isn't hard) As long as you get some decent fans. |
#25 | |
I just finished installing this today and works. At first I was like the fans aren't working WTF?!?!?! Took a drive and then opened to hood to find the fans spinning. I wired the yellow wire, the ignition wire, right into the radio fuse and works like a charm. Also installing the isis radiator was a breeze!!! Removing the clutch fan wasn't but we got it done!!!! Tomorrow is making the wires look pretty!!!! ![]() |
#26 | |
#27 | |
#28 | |
I'll post pics up tomorrow. |
#30 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
Clutch fans are bulky, loud, and in the way. That alone was enough to make me switch. With 30 some odd track days under my belt, I can assure you that I've never EVER had an overheating issue with Altima fans. Sure a clutch fan works fine...it's almost failsafe...but I can't stand them being in the way.
