Sr20 starting problem
My sr20 will not start. It will turn over but not fire. I can get it to start if I pull the 10A fuse for the fuel pump, let it die and then put the fuse back in and fire up the car. The spark plugs are cheap ass champion bullshit with a black base, and the side electrode being white. The cylinder second from the firewall has a broken off insulator tip. Once the car turn on it will run and pull fine though. My only guess is that the spark plugs aren't cold enough and I need to get new NGK's and drop these champion ones that I bought the car with. On the fuse chart the fuse for the fuel pump (walbro) is 15A but the one I have is 10A do I need to change that? Why is the car not starting?
the fuse isnt going to keep the car from starting, if anything it will just blow more often, if you replace it i wouldnt go higher than 15a, but you do need to scrap those cheap plugs and get some ngk's,
![]() Join Date: Jun 2003
Trader Rating: (129)
sounds like your car is flooding out for for some reason. check your fpr, get some fresh plugs, and replace your fuse with the correct one.
you can use ngk coppers (iirc its bkr6e? or bkr7e will work fine) they're cheap but don't last as long as iridiums or platinums fuse should be like $3 for a whole box. |
NGK iridiums AutoZone.com | | Spark Plug | NGK IRIDIUM IX Bosch AutoZone.com | | Spark Plug | BOSCH SUPER PLUS |
a quick search would get you #/f/engine-tech/2816...ark-plugs.html
I used the bosch coppers and the car runs fine. Turns on now. The starter is making a grinding noise after the motor starts running but from my past experiences with this in a VW all it needs is some grease.
Just took the car out for a drive. Started fine at my house 2-3 times. I get to where I was going to go, turn the car off come back 5 minutes later and try to start it and it happens again. I drive home turn the car off and right back on a second later and it starts with the starter grinding.
do you have any fpr? aftermarket fuel pump? are your fuel lines hooked up correctly?(and what other mods do u have, ppl need tro give better info in 1st post..)
if u can start the motor by dis-abling the fuel pump your shits getting flooded (most likely) or maybe ur IACV is an issue. when it doesnt start do u try it a WOT? maybe u need more air. maybe the motor thinks its cold so it "chokes" it ( no air/lots of fuel) as for the grinding starter i dont think its related... EDIT: i gap my bkr7e's at 25, but i kno guys that use 32....both our cars run fine... EDIT, i just read the whole thread lol, iridium plugs are not good for boosted motors. they are way too fucking expensive and they DONT LAST AS LONG. search around here for that info. BKR7E only plug to use. cheap as hell at autozone
@UpshiftEngineering |
WOT wont help. I think its the FPR but a friend of mine says it might be the O rings. I think the only mod that matters in this problem is my walbro pump. Everything else is a FMIC, catch can, koyo radiator, RA stoppers, apexi N1, heavy duty clutch, everything is suspension. The plugs I installed are the bosch coppers (2.50 each) gapped at 30 for now until I put an order on Bkr's. How would I find out if its the FPR or the Rings?
No I mean with there being no vacuum to the fpr would the fpr close or open. Found the answer myself, already orderd the FPR from phase2 so we will see when I get it in next week.
Update - Just installed my new Adjustable FPR, set it to 40psi with the vac line disconnected. Drove around fine came home to see if it would start and it wouldnt. I pulled the fuel rail out of the manifold and set them on top of some cardboard, turned the ignition on but didnt start the car.... No leaks. HALLLLLLLLP
#17 |
You need to have the fp set to 40 psi with the vacuum line CONNECTED.
Maybe this is part of your issue. Way too much fuel.
Like Me on FaceBook !
#19 | |
ya u have alot of fuel there...mines been at 35(connected) for a while now running damn well
#25 |
Got one code: 13. For coolant sensor. It was unplugged when I bought the car, drove it for a while and then realized it was unplugged, plugged it in and it didnt make a difference. I removed the old sensor, while putting in the new one I snapped of the plastic connector revealing the sensor. Im kind of pissed but nothing I can do, lost 23 bucks and have to find another store that carries it.
