Old 03-28-2012, 12:04 PM   #1
ke70 sr20det
ke70 sr20det is an unknown quantity at this point
SR sr20 retop maf problem help needed
hi recently my car was perfectly fine running after the swap for about 1.5 year and been driving the engine from 2007 from my silvia no issue ... past two days the car starts perfectly fine idles perfectly fine but between 1500 to 3000 or 4000 rpms (no tacho) car missing alot after that goes all way up to red line
when i unplug or plug maf it idles same 800 to 900 rpms very normal checked everything no clue except this
feedback is appriciated zilvians
ke70 corolla sr20det redtop t28 s15 7 psi stock motor
ke70 sr20det is offline   Reply With Quote
Old 03-28-2012, 02:43 PM   #2
0wn3r
0wn3r's Avatar
0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of0wn3r has much to be proud of
Based on your searches of MAF problems throughout the forum, what have you done so far to try and correct the problem?
Have you, sprayed the sensor with MAF cleaner?
97 240sx se
0wn3r is offline   Reply With Quote
