![]() Join Date: Nov 2007
slipping clutch
i just put a new clutch on my car and after like 200 miles it starts to slip i have already adjusted the clutch masters rod all the way out and my slave is extended all the way any any ideas and yes i just searched
![]() Join Date: Oct 2007
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
did you break it in properly? usually when you have a new clutch, its best to stay below 3500rpm and dont do any hard launches for about 500-600 miles. also check to see if you have any fluid in your master cylinder.
#3 | |
![]() Join Date: Sep 2002
Also, did you resurface/have resurfaced your flywheel when you replaced the clutch?
#6 | |
Ding ding!!!
Problem identified!
#8 | |
![]() Join Date: Nov 2006
Also, if your clutch is a cheap or organic clutch.... they usually don't last long with abuse.
![]() Quote:
