![]() Join Date: Oct 2008
I've already searched all over this forum as well as others and I learned that if the Timing Control Unit or TCU (little white box behind the driver side kick panel) is fried, it will cause your dash light to malfunction. So I have a question regarding this TCU:
1) if this unit fails, will it not only shut off my dash light, but also my digital speedo? 2) How can I tell if my TCU is fried? Assuming I've taken it off and opened it up, what do I look for?? This is for an '89 coupe sohc. please help, thanks.
Bone in and Bone out! |
Okay, check it out. I had a problem disconnecting the tcu from it's harness because it's hurting my fingers x(
Anyway, I happened to notice slight discoloration on the back of the module itself. The entire box is made of plastic and when this type of plastic is damaged or morphed (burned) you get discoloration like this.. I think. Could my theory be wrong? or is this box fried?
![]() Join Date: Jun 2010
Not sure on the speedo(it could just be that you have a bad HUD or your wiring is loose behind the cluster) but the TCU controls the dash lights, clilmate control, and the glove box light..You're gonna have to open it up and check for black discoloration somewhere on the board..they're a little bit of a pain to get open, the easiest way i found was to take a flat tip screw driver and pop each "latch" open one at a time..also make sure when you put it back together the board is lined up with the grooves inside the case.
#4 | |
I will inspect them once more to eliminate my TCU as the source of my problem. (Dashlight doesn't light up). So if it's not my TCU, what else could it be? Cluster Bulb perhaps?
#6 | |
![]() Join Date: Apr 2004
The easiest way is to swap your TCU int a car that is working correctly. Don't put the good TCU into your car because whatever is wrong with your car may damage the good TCU. |
