![]() Join Date: Mar 2006
'95 S14 SE, blacktop S13 SR20, 2871R, fully built head, full body kit, full susp, BBK
FOR SALE: $12,000 OBO---CASH ONLY
Hi everyone---I used to be very active on here in the 2006-2011 time frame. During that time, I spent over $27,000 modifying a mint clean 95 SE. It was sold to me by my father with 186,000 of highway only driving on it and was garaged up until that time--needless to say, quite a dream. Selling because I just don't have the time to drive it any more or give it the love it needs---it deserves to be on a track! Also---I have another daily driver that I really enjoy driving. Key highlights include (full mod list below pictures...it is long!): - Apex'i PowerFC Standalone ECU - GT2871R - Fully built head with HKS Step 2 264 cams - Greddy Intake Manifold - Externally gated stock exhaust manifold, swain coated - Full body kit with kouki S14 front end conversion - Makes approximately 350hp/300 ft-lbs at 17 psi (turbo can easily do 20 psi!), tuned by Jeff Evans in PA - Wilwood big brake kit - Very extensive suspension replacements (see below for full list) Full Modification List, Original Price Paid, and Mileage Installed/Performed (current mileage is ~222,000)
![]() Daily driven |
![]() Join Date: Jun 2008
Bump. I too am no longer active but your insight and willingness to share knowledge has been much appreciated. This is a KILLER deal for a well sorted car from someone who obviously doesn't cut corners.
Thanks for the kind words!
I miss being active on here and modding the car but adulthood has gotten in the way along with other priorities....sucks....
Do you have any engine photos available bro?
And also what are the compression numbers per cylinder? I just want to make sure that the bearings and cylinder piston rings are good too. Last edited by KoukiOfSaTx; 04-08-2016 at 10:49 AM.. Reason: typo |
Hi Everyone---here are a few interior and engine bay pics. Apologies for the quality. It's snowing out and car is in the garage. I refuse to use flash because it gives a bad view of the relative colors/textures of surfaces. The engine bay pics were on a tripod with long exposure, but the interior shots I had to steady my hand the best I could---they are a bit blurry, but the read on the colors/textures is accurate.
#15 | ||
I can certainly check again when it's warm out and I take the car out, but I recall them being in the 145-150 range for all 4 cylinders No smoke, little/no oil consumption, etc. Quote:
I have electric fan with a switched thermostat, which I have set up for the fans to come on only if the coolant temp hits ~85-86C. Under normal driving at 40-50 mph or more, the coolant temp. is usually stable in the 80-82C range.
| body kit, gt2871r, kouki, sr20, swap |
