AEM Map sensor
Going to get a AEM Ecu, I was searching around and couldn't find any pics, but does anyone know the best location to run the map sensor on the SR?
yea the IAT sensor can fit in the IC piping but the MAP sensor needs vac but I just wanted to see if anyone had pics on where they installed theirs. I never ran one before just want to get it in the best spot the first time around.
I see, yea looking at the setup it either looks like it can thread in or you can run that extra fitting to run a rubber hose to it for vac. I suppose anywhere before the TB on the intake should be fine?
