Old 04-07-2009, 08:52 PM   #1
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
S13 w/ S14 LCA,spindle = S14 Tie rods in/out?
trying to confirm if I'm running Full S14 LCA and Kunckle up front,..do I need a Set of Inner and outer's for S14 or S13 inner and S14 out?
Last peice of my Build puzzle really.
Guess it wouldn't matter as they should all be the same (S13/S14) or The Rack is what makes them Diff S13 to S14?
z-tERty-2
MrFairlady is offline   Reply With Quote
Old 04-07-2009, 08:57 PM   #2
Sileighty_85
Sileighty_85's Avatar
you can use S13 tie rods and ball joints with the S14 knuckles
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-07-2009, 08:58 PM   #3
whyrun?
whyrun? is an unknown quantity at this point
when i put my 5 lug on my s13 i originally used S14 lca's w/ s13 tie rods and i had some wierd toe. i put my s13 lca's back on for the time being.
whyrun? is offline   Reply With Quote
Old 04-08-2009, 07:47 AM   #4
projectRDM
projectRDM's Avatar
The S14 LCA is 15mm longer, hence the toe issues. You can realign it just fine.
As to the OP- The S13 tie rod is a smaller diameter so you cannot mix/match tie rod ends between chassis. You can use however either one as a set, S13 or S14, or Z32, Z33, etc. like SPL will suggest to you on their site. The spindle hole for the tie rod end is the same size.
FORMERLY R240NA
Old 04-08-2009, 08:00 AM   #5
SoSideways
SoSideways's Avatar
You can't use S13 ball joints with the S14 knuckles.
The ball joint stud taper is different between the S13 and S14 ball joints, and knuckles too.
Old 04-08-2009, 08:52 AM   #6
whyrun?
This man is correct. You can do it, BUT ITS NOT SAFE TO OPERATE ON ANY ROADWAY.
Thank you RDM. So 15mm longer, that gives me 30mm total more tract?
Old 04-08-2009, 08:54 AM   #7
Sileighty_85
haha i fail at explaining
I was refering to the outer Tie Rod ball joints not the LCA ball joints. :P
後輪駆動車1番
1986 SR86 - 200ish
Old 04-08-2009, 10:31 AM   #8
projectRDM
projectRDM's Avatar
Correct. You then dial the camber back out up top, as the added length affects the camber a little.
FORMERLY R240NA
Old 04-08-2009, 01:46 PM   #9
Gription
Gription's Avatar
Gription is an unknown quantity at this point
Send a message via AIM to Gription
Just to make sure I am understanding all of this correctly;
To use S14 front spindles on and S13 you NEED S14 control arms (that's with s14 ball joints, not s13 ball joints correct?), you can use S13 inner and outer tie rods, and everything else will bolt up without any issues correct?
Then, the extra 15mm length of the s14 control arms will result in more negative camber in conjunction with S13 tie rods correct?
I am about to do this swap and I want to make sure I have everything I need before I get started.
Gription is offline   Reply With Quote
Old 04-08-2009, 02:31 PM   #10
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
correct.
BUT you dont have to use the s-14 lower control arm, you can use s-13 lower control arm and press in s-14 ball joint.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 04-08-2009, 09:16 PM   #11
Gription
Gription's Avatar
Yeah, I know that is an option but I'm going for more camber. And and s14 lca's WILL work without modding right?
Old 04-08-2009, 09:20 PM   #12
singlecamslam
You have to buy the little adapters for the mounting holes on the spindle because s14 uses 14 mm bolts and s13 uses 12mm. You can buy them or drill it out.
singlecamslam is offline   Reply With Quote
Old 04-08-2009, 09:35 PM   #13
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
I believe you get a tad more neg camber w/ the Full LCA which is what I'm running.
**Thread jack Over**
All my stuff is already installed.
I lost the Nuts (that secure it to the Spindle) to my Outer Tie rod ends and don't want to "Rig" ANYTHING w/ them so I guess I'll get some new ones - Trying to figure out what to buy.May Go SPL being this is something that Gets SERIOUS Abuse.
Needed to know which to buy S14,S13 or whatever - Guess I can ask SPL what they would run.
z-tERty-2
Old 04-09-2009, 06:37 AM   #14
projectRDM
projectRDM's Avatar
Direct bolt on. Nothing is required.
FORMERLY R240NA
Old 05-09-2009, 10:56 AM   #15
luckky
luckky is an unknown quantity at this point
so there is to options correct?
option #1 - s14 spindle, s14 lca including s14 balljoint, and all s13 tie rods.
option #2 - s14 spindle, s13 lca, s14 pressed in balljoint, and all s13 tie rods.
i am also in same position because i cheaped out and got conversion hubs and they are not doing the trick for me! So i want to make sure also that i buy the right shit seeing i will be going to the dealer to get it and i would rather not spend all the money only to find out i bought the wrong stuff. Thanks zilvia for all help!
the rollin elite
luckky is offline   Reply With Quote
Old 05-09-2009, 11:18 AM   #16
singlecamslam
option #2 - s14 spindle, s14 lca, s13 pressed in balljoint, and all s13 tie rods.
Its not hard to understand. If you have the s14 spindle you NEED s14 balljoint. Doesnt matter if its an s13 LCA, s14 spindle goes only with s14 balljoint.
Old 05-09-2009, 03:08 PM   #17
luckky
true, edited my second option
the rollin elite
