Old 11-04-2008, 06:09 AM   #61
l0lzilla
l0lzilla is an unknown quantity at this point
Gangsta build +1
l0lzilla is offline   Reply With Quote
Old 11-05-2008, 10:43 PM   #62
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
Ok so... Time for another update.
Started working on the fuel cell setup. It will be hidden by a firewall and then carpeted over.
First thing was to remove the old sheet metal with the Hypertherm 800 plasma cutter.
Then grind everything smooth.
Here is our cell. Its just a regular Black powder coated 15 gallon aluminum cell with a level sender.
Then I started work on something that is really going to "make" this car legendary. The custom sub frame that will also act as a complete chassis stiffener.
First thing I did was make the mounts for the main pickup points for the new subframe.
These are 1.5" od .095" wall DOM tubing
Then I grabbed some grade 8 washers, and sanded all the zinc coating off. Then tacked them in place.
I then tig welded them all up.
And bolted them in the oem location.
Then I measured where the stock Suspension arm pickup point was. It was located 3.75" down, and 3.25" inward of the chassis.
I then notched some tubing at the correct 50 degree angle, and tacked everything in place.
After that was all confirmed I tig welded everything together.
This took awhile.
I then attached all the super baller suspension components, and confirmed fitment.
More updates tomorrow. I hope you have enjoyed todays work.
Luke.
blu808 is offline   Reply With Quote
Old 11-05-2008, 10:53 PM   #63
gunluvS14
gunluvS14's Avatar
gunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura about
interesting
subscribed
#/f/image.php?type=sigpic&userid=45706&dateline=118722  3315
gunluvS14 is offline   Reply With Quote
Old 11-05-2008, 11:37 PM   #64
GSXRJJordan
GSXRJJordan's Avatar
Looks like that little piece of the frame rail needs a big "L" piece welded in to make sure you don't bend that 'lip' with all the torsion that the LCA's going to generate.
As always, baller work Luke! Welds look insane.
Old 11-05-2008, 11:59 PM   #65
SaintlyCharBoy
SaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her selfSaintlyCharBoy is making a name for him/her self
Send a message via ICQ to SaintlyCharBoy Send a message via AIM to SaintlyCharBoy Send a message via Yahoo to SaintlyCharBoy
luke, do you plan to connect the drop brackets to one another (left to right)?
92 vert - KADE + VH41 + GM MA5 = too many parts in the garage
95 base - retired
SaintlyCharBoy is offline   Reply With Quote
Old 11-06-2008, 12:31 AM   #66
burnsauto
burnsauto's Avatar
burnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfection
Send a message via AIM to burnsauto
luke..looking at the pic you posted about the turbo elbow clearance, hows the steering shaft clearance looking?
burnsauto is offline   Reply With Quote
Old 11-06-2008, 12:43 AM   #67
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
Would i be correct to assume those brackets you just made are going to tie into an entire tubular subframe? Your fab skills are insane. Looking forward to more step by step detailed pics like these!!!
96Turbo is offline   Reply With Quote
Old 11-06-2008, 01:49 AM   #68
blu808
blu808's Avatar
thanks guys. We could of easily made these from box tubing. the parallel down tubes will be the main connection to the front part holding the steering rack, and front strut brace. the rear will tie into the tension arm mount, fire wall, and lower chassis. it will make perfect sense once you guys see it.
Old 11-06-2008, 02:18 AM   #69
BlueKpS13
BlueKpS13's Avatar
BlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to all
fabbing up the suspension is getting my attention...and i love a good Z
subscribed
BlueKpS13 is offline   Reply With Quote
Old 11-06-2008, 05:21 AM   #70
derek_s13
derek_s13's Avatar
derek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant futurederek_s13 has a brilliant future
Send a message via AIM to derek_s13
this is awesome. no fear diving into this build.
derek_s13 is offline   Reply With Quote
Old 11-06-2008, 06:44 AM   #71
gregfarz78
gregfarz78 is on a distinguished road
damn you do some top notch work man
gregfarz78 is offline   Reply With Quote
Old 11-06-2008, 09:14 AM   #72
Om1kron
Om1kron's Avatar
I will await to see more, but how will the frame not tug with those two little points mounted to the frame rails. I'm no metal expert but just curious.
I don't know much about suspension geometry either but how much stress is the suspension being mounted to this thin piece of metal going to hold up?
Wayne
Old 11-06-2008, 09:41 AM   #73
ramman434
ramman434's Avatar
ramman434 will become famous soon enoughramman434 will become famous soon enoughramman434 will become famous soon enough
I was wondering the same thing^^.
This build is going to be awesome, subscribed
ramman434 is offline   Reply With Quote
Old 11-06-2008, 11:29 AM   #74
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
i would kill for these skills u have blu amazing man
Old 11-06-2008, 02:22 PM   #75
blu808
blu808's Avatar
Thanks guys. Those are actually the factory subframe mount locations.
Its kind of hard to describe, but everything will make sense once you guys see it.
Old 11-06-2008, 03:21 PM   #76
jt1583
jt1583 is making a name for him/her selfjt1583 is making a name for him/her self
work faster!
ha jk very nice to look at. great work.
jt1583 is offline   Reply With Quote
Old 11-06-2008, 03:28 PM   #77
GSXRJJordan
Originally Posted by blu808 View Post
...but everything will make sense once you guys see it.
I believe! Ooohhhhhhh Lawwwdddayyyy, I BELIEVE!!!1!one!
lolz. Can't wait to see more! MOAR!
Old 11-06-2008, 10:43 PM   #78
blu808
blu808's Avatar
Another update.
Today we started work on the driver side LCA mount.
And made most of the bracket for that side.
We spent the rest of the day figuring out the steering rack, tie rods, etc.
More pics coming tomorrow.
Old 11-06-2008, 10:44 PM   #79
GSXRJJordan
Turrrbooooo!!!!
Old 11-06-2008, 10:56 PM   #80
blu808
blu808's Avatar
Yes. Turbo misses his new BF. He was wondering when you are coming back.
Old 11-06-2008, 11:10 PM   #81
CursedGTR
CursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfectionCursedGTR is close to perfection
Absolutely beautiful work.
CursedGTR is offline   Reply With Quote
Old 11-06-2008, 11:12 PM   #82
blu808
blu808's Avatar
Thanks man! The Dog (turbo) does all our welding. I will let him know how you feel.
Old 11-06-2008, 11:19 PM   #83
rc1honda
rc1honda's Avatar
rc1honda is an unknown quantity at this point
wow i wish i had half the know how these guys have. Thats how i wanna build my car. The right way.
rc1honda is offline   Reply With Quote
Old 11-06-2008, 11:50 PM   #84
anthony240
anthony240's Avatar
anthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really niceanthony240 is just really nice
Send a message via AIM to anthony240
good boy?..
18+ to come//21+ to swallow
anthony240 is offline   Reply With Quote
Old 11-07-2008, 01:27 AM   #85
Fonix36
Fonix36's Avatar
Trader Rating: (34)
Fonix36 is just really niceFonix36 is just really niceFonix36 is just really niceFonix36 is just really niceFonix36 is just really niceFonix36 is just really niceFonix36 is just really niceFonix36 is just really nice
Feedback Score: 34 reviews
Send a message via AIM to Fonix36 Send a message via Yahoo to Fonix36
my balls are blue now
DRiFT 4 A Cure!
Fonix36 is offline   Reply With Quote
Old 11-08-2008, 05:17 PM   #86
blu808
blu808's Avatar
Ok here is a little update for today.
We decided to test fit the ZG fender flares.
Surprisingly the flares fit right up with little issues or gaps.
We also mounted the rear wing. It also fit very well with no issues.
We also put the 350z seats in to check clearance, and measure for brackets.
Ohh, what do we have here? A steering rack clearing the rb26 oil pan while still retaining the original steering linkage and geometry. We have more on how it will all be mounted up later.
Hope you have enjoyed todays work.
Old 11-08-2008, 10:27 PM   #87
74260zt
74260zt is an unknown quantity at this point
Nice build up. Glad to see you come over the HybridZ.
Here is my 74rb26dettZ >> 74260zt/rb26powered74zcar - Photobucket - Video and Image Hosting
joel
74 rb26Z
photobucket.com/RB26powered74zcar
74260zt is offline   Reply With Quote
Old 11-08-2008, 10:51 PM   #88
stonehac
stonehac is an unknown quantity at this point
Cool pics keep us all posted here's mine.
don't let the hood scoop deceive you its an RB26!!!
stonehac is offline   Reply With Quote
Old 11-09-2008, 12:21 AM   #89
blu808
blu808's Avatar
Glad to see you post here. Your engine bay is my current screen saver at the shop. Really diggin the radiator, intake mani, and fmic, along with the turbo setup, engine, engine bay, interior, body, wheels, etc. lol
joel
Old 11-09-2008, 12:22 AM   #90
blu808
blu808's Avatar
I have been watching the progress of your car for quite some time now. I really like your front tube frame design.
Luke
