![]() Join Date: Feb 2011
What was the last thing you did before this started to happen? The wiring diagram will help you narrow down where the short is by letting you know what parts are connected to that fuse. You don't waste time looking at another portion that isn't even connected to what you're looking for. And as far as your problem goes, something must be grounding out, possibly a pinched wire or if you did wiring then something was hooked up wrong.
Banned from the Marketplace
Never had this problem until yesterday, I replaced my battery terminals and I replaced a couple tail light bulbs, but that couldn't be related to the ignition fuse right?
Sent from my SPH-L720 using Tapatalk |
UPDATE: Turns out I rubbed the harness that runs next to the front wheel when I lowered my coils. fixed the insulation on the worn wires, popped in a new fuse and I'm good to go! Also relocated the harness so I dont have this issue in the future.
