vis 25mm rear over fender install gone wrong?
they only make 25mm & 50mm Carbon Fiber Hood, Trunk, Hatch, Body Kits Megastore - Vis Racing Sports Inc. but why does the passenger side look bigger then driver side? I used: -SEM multi-purpose panel adhesive -rivets just to hold the panel to stick to metal n cure for 24hrs look at the pics tell me wat u guys think? passenger side ![]() driver side ![]() EDIT:the fenders are on now. just to finish off this thread. finished wet sand and guide coat everything is straight no low or hight spots ![]() so smooth! i have kouki aero so it will just go over the bottom sections ![]() ![]() ![]() anyone have questions on how to ill be glad to help out.
![]() Join Date: Sep 2009
passenger side looks like a 50mm..cant tell you whats wrong..i have some dmax over fenders waiting at my house to be put on..im ganna have a shop do it just to make sure everythings done right.
i bought these from sonic motor i called they said these fenders could be mod. to go 30mm or 25mm
im going to have to stop by their shop so they can take a look ahh so much work to put these on ...:/
hmm thats weird and confusing. I live right by moval. off the 60 and van buran lol.. anyways good luck man. Im real anal so im hoping if i have a shop do my overfenders that it will be perfect. id hate to fuck something up.
![]() Join Date: Feb 2005
Ya, you probably just bowed one. Pretty fucking useless to fit the fenders without proper fitting wheels on. What did you use as a guide when mounting? Just line up and rivet on?
Wheels first. Then fenders. No one ever gets that right. |
#10 | |
no your wrong. body work then paint then wheels. you dont want to get paint on your wheels. so you use wheels that you dont really care about. stay on topic no smartasses
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
You don't get it.
He means having the proper fitting wheels first(aka sticking way past stock fenders for you to need overfenders.) Both of them would be sticking out evenly if your desired alignment is set. THEN install overfenders and play with the overfender fitment to be as flush as possible with the wheel fitment. That way, both are bowed or fitted to be the same size on both sides. You'd be a dumbass to paint your car with expensive wheels on it.(That's what rollers are for). |
Hey bro...its me David.. Im getting ready to the same to my car.... Ive done a few bodykits but no widebodys yet. I do know the heat and how long they have been sitting at the warehouse make a big difference.
The rear of this kit was actually 3 inches wider on one side...I had to heat it to get it to fit right. |
yes i do have the proper wheels.
and proper offset for 25mm overfender with a good camber to set them in. and my car is slammed as you can see in my signature. Im doing BODY work so i raised the car and put my stock SE wheels. raised it so i can get paint under the wheels wells and stock wheels so i dont get over spray on my good wheels im just asking if one side looks bigger then the other thats all. thanks
I had bought some over fenders from VIS around a year ago and they were packaged up and everything. Installed them and same thing as you. One was a 30mm and one was a 50mm. Took about 2 months of driving around with one over fender until they gave me another one. Also we recently put some over fenders on "TheSquidds" new car that were also purchased through VIS. Same thing happened with him and the opposite side was the 50mm. Weird. It is not Sonic Motors fault. If anything VIS is slacking on that packaging.
i used clecos
Sheet holders provide the quickest method for holding sheets together for drilling or riveting. Drill the size hole needed for the rivet and insert the sheet holder. Sheet Holders Sheet Metal Tools from Aircraft Spruce and sems panel adhesive ill show some more pics on how i install these in a bit
#16 | |
yeah thats prob what happend to me ahh... ![]() i talked to sonic motors already they just said maybe i installed them wrong?? they also said they want to take a look at it. so i might roll threw 2morow. hopefully they can replace the fender without taking to long kinda sucks that the fenders are glued on. so much work to line up and put these on and i might have to grind them off.
#17 | |
idont think i can heat it. if i did it will get worse and maybe crack
#18 | |
Put your good fitting wheels on with your coils set at the ride height you drive at. THEN fit the fenders TO THE WHEELS. Once you see everything fits right, raise it back up and put the stock wheels on for paint. I wasn't being a smart ass. Although like socals130 said you might have two different fenders. So.... when(if) you get your new fenders install the way I recommended. It will make for better fitment. Good luck. |
#19 |
1 grind to metal
![]() 2 clean with wax grease remover and apply panel adheisive ![]() 3 hold in place with clecos ![]() let it sit for 24hrs then remove clecos and your done
#23 |
![]() Join Date: Sep 2006
so isnt all that bare metal going to rust now? i undestand some of it will actuall be sealed between the fender but it looks like a lot will remain exposed in the fender
#24 | |
![]() Join Date: Feb 2008
![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
That shit looks jacked up.
SPLparts.com * PoweredByMax.net Quote:
#25 | |
![]() Join Date: Jan 2004
Trader Rating: (82)
![]() Feedback Score: 82 reviews
loks good how it came out but what about all the bare metal u left exposed? it will rust? did u spray at least some treatment anything? ill be worried about that |
#26 |
you can evenly spread that epoxy threw the metal try to cover wat you can.
clecos was used to line up the fender in place. and rivets are temporary just to sandwich the epoxy to metal and fiberglassl untill it cures for 24hrs then they come off. these are goign to be molded in so they wont be no rust. this epoxy only bites into metal or fiberglass and it used on panels like on what im doing. heres a short video http://www.youtube.com/watch?v=yZc7qvwPycE im using evercoat fiber tech filler to mold these in and finishing it off with evercoat everglass short strand maybe even a small coat of SEM Finishing Glaze on top it should come out smooth these fillers are strong and flexible onced cured. so i called sonich motors again they said yes they have been having that problem with VIS packaging the wrong fenders sizes. they are going to try to replace the fenders for me and get the right size. so i need to grind these overfenders off and put the right size fenders on all over again... ![]()
#27 | |
not when you use that epoxy all pressure has to be evenly on all sides. and i used smallest rivets 1/8 so it will be easier to cover up.
#30 | |
this is the correct way to attach fiberglass to quater panels if your planning on molding the overfenders SEM Products - Catalog
