Old 11-19-2010, 12:26 PM   #1
95_sr20det_240sx
95_sr20det_240sx is an unknown quantity at this point
Weird Popping noise
I have so far changed in the last 5 months tie rods inner and outer, wheel bearing (passenger side), and ball joint (passenger side). But now there is this loud popping noise when i turn the steering wheel to the right it pops and then when I turn it back it pops and depending on how far i turn it depends on how many times it pops and ideas. I also has a Apexi N1 coil over suspension under it. and lowered.
95_sr20det_240sx is offline   Reply With Quote
Old 11-20-2010, 09:43 AM   #2
CLM_s13Type-x
CLM_s13Type-x is an unknown quantity at this point
What about your tension rod bushings? are they new or busted? Also check the brackets for the tension rods that bolt to the bottom of the rad support. The bolts were loose on mine one time and it made a popping sound. Just some suggestions.....
CLM_s13Type-x is offline   Reply With Quote
Old 11-22-2010, 06:18 PM   #3
kojiki88
kojiki88's Avatar
kojiki88 is an unknown quantity at this point
Good suggestions, I'm having the same problem. It's getting irritating the only two things that I still haven't changed are the tension rods and steering rack bushings. Also if I have the wheels turned a little to the right and hit the brakes with medium force it will make that popping sound. Or when backing up and I turn the wheel all the way to the right it will do that sound about two times. Weird but I feel that sound coming from behind the firewall under my feet.
kojiki88 is offline   Reply With Quote
Old 11-22-2010, 07:13 PM   #4
drift213
drift213's Avatar
drift213 is an unknown quantity at this point
coilovers tend to make clunk noises so idk
LOTS OF SR20,ka24de,s13 goodies for sale check my threds
drift213 is offline   Reply With Quote
Old 11-24-2010, 09:00 AM   #5
95_sr20det_240sx
Thanks guys will check all that. pretty sure not the coilover. but wil look it over later this weekend after all the thanksgiving stuff is done lol
Old 11-24-2010, 09:48 AM   #6
S14DB
AFC #1
S14DB's Avatar
Check the top nuts on the coilovers.
Old 03-14-2011, 05:32 PM   #7
kojiki88
kojiki88's Avatar
Ok so I recently changed my steering rack bushings and Tension Rods and nothing. The noise is still there. I don't know what else to do and or look for. Like ^^ he said I'm going to check the top nuts on the coils this weekend. 95_sr20det Have you found out something towards the problem that I don't know of?
Old 03-14-2011, 06:08 PM   #8
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
I had a problem like this and it was the ball joint thing at the top of the coils, got rid of those and no more noise for me.
jacobs13 is offline   Reply With Quote
Old 03-15-2011, 05:29 AM   #9
SlidingMooch
SlidingMooch is an unknown quantity at this point
Send a message via AIM to SlidingMooch
Agreed With Everyone Else, Thats A Coilover Problem, My Sil80 Had The Same Problem For A Little While.
SlidingMooch is offline   Reply With Quote
Old 03-16-2011, 05:18 PM   #10
kojiki88
kojiki88's Avatar
What did you actually do to solve the problem?
